Author Topic: Memory seats  (Read 3773 times)
boss
  • Lesta
  • Fat Contoller
Memory seats
« on: 13 July 2006, 13:22:30 »
Right my seats all work ok, but I'm at a loss as how to use the actual memory part??
It seems that I cant save the seat and mirror settings or recall them??
Ideas anyone? Is there a trick to this?
Everything imagined, exists......somewhere....
Salty
  • Fleetwood
Re: Memory seats
« Reply #1 on: 13 July 2006, 13:26:12 »
The seat and mirror position is stored by pressing the M button and one of the number buttons together
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: Memory seats
« Reply #2 on: 13 July 2006, 13:26:41 »
Set up seat and when happy just press the M and either the 1,2, or 3 button, for a couple of seconds.
That should remember you position till it is overwritten.
But I presume you have done this already, and it doesn't work!
Re: Memory seats
« Reply #3 on: 13 July 2006, 13:30:37 »
and to recall, you have to press AND HOLD the associated button you stored it under...
boss
  • Lesta
  • Fat Contoller
Re: Memory seats
« Reply #4 on: 13 July 2006, 13:39:11 »
Yep have done this......as it says in the owners manual.
I see from the wiring diagrams that the exterior mirrors, interior mirror and seats are all wired through an ecu of some sorts.
As all functions but the memory work, could the fault be with the ecu/memory part?
Re: Memory seats
« Reply #5 on: 13 July 2006, 16:00:16 »
Its possible but, it could also be the permanent live feed at fault resulting in altsiemers
Re: Memory seats
« Reply #6 on: 13 July 2006, 16:02:51 »
Mark, you've forgotten how to spell. Must be your alzheimers...
Re: Memory seats
« Reply #7 on: 13 July 2006, 16:44:31 »
Its coz we dont have a spell checker on here!
Salty
  • Fleetwood
Re: Memory seats
« Reply #8 on: 13 July 2006, 16:50:24 »
What actually happens when you press one of the memory positions?
martin42
Re: Memory seats
« Reply #9 on: 31 July 2013, 13:37:50 »
This happens
Re: Memory seats
« Reply #10 on: 31 July 2013, 14:07:24 »
Trying moving the seat to a completely random position and then press and hold one of the number buttons...
I suspect you have saved the same position in all three memories, and unless you move the seat out of position, nothing will happen because the seat is already in the stored position :y
