Author Topic: Front door loom connector  (Read 13330 times)
« on: 12 July 2006, 12:26:31 »
I'm still trying to fix my intermittent speaker in drivers door - looks like its wiring between headunit and speaker.
I assume there is a connector near where the loom joins the door, but before stripping down, wondered if anyone knew if the connector was in the door, or just above the drivers kick panel?
Re: Front door loom connector
« Reply #1 on: 12 July 2006, 12:35:00 »
Its easier than that, open the door and look at the hinge area....there is a dity great big multiway connector with a twist lock assembly on it for the front doors
« Reply #2 on: 12 July 2006, 12:44:21 »
Brilliant, thanks Mark :D
Does this connector get a bit dirty - could that be cause of my probs?
« Reply #3 on: 12 July 2006, 13:05:36 »
Never known it cause problems, probably more likely to be a failing voice coil in the speaker I would have thought.
« Reply #4 on: 12 July 2006, 13:09:41 »
Already changed the speaker, though it was one from a car being scrapped. Same problem though, hence why I suspect wiring (replaced headunit as well)
« Reply #5 on: 12 July 2006, 13:27:58 »
Is the door tweeter working?
« Reply #6 on: 12 July 2006, 13:31:55 »
The whole thing is intermittent, but I think the tweeter goes off as well :(
I'll pay more attention next time, but if tweeter says on, would that prove its speaker?
« Reply #7 on: 12 July 2006, 13:34:07 »
It proves the loom to the door is ok, if the tweeter does go off then start at the door connector and work back to the stereo whilst measuring for 8ohm from the door speaker.
« Reply #8 on: 12 July 2006, 13:36:20 »
I shall have a look at that connector tonight, then it it happens again, pay more attention to the tweeter.
Thanks Mark  [smiley=thumbsup.gif]
« Reply #9 on: 12 July 2006, 15:30:21 »
This may sound dumb, but I can't work out how to undo connector  :-[  - I can't really see enough to work it out.  It twists slightly, but wont pull out.  The is a little red clip thing on it, does this need to come off first? If so, how? Tried pulling, but it appears not to want to budge.
« Reply #10 on: 12 July 2006, 15:48:44 »
The nurled collar section twists first, it goes stiff as it passes over an indent before you can pull and remove.
The red plastic tadger does nowt.
« Reply #11 on: 12 July 2006, 15:49:57 »
Ta, I'll have another go :) (didn't wanna break it)
« Last Edit: 12 July 2006, 15:50:18 by TheBoy »
« Reply #12 on: 12 July 2006, 15:51:08 »
In view of fact I have side airbags, and there is a pressure sensor in the door, do I need to disconnect battery?
« Reply #13 on: 12 July 2006, 16:12:19 »
Dont turn the ignition on......
« Reply #14 on: 12 July 2006, 16:15:15 »
Had another go, the whole thing turns anticlockwise, about 15 degrees (and over a notch in the process). Try as I might though, I can't seem to pull it out.  Am I doing everything right before I get some big tools on it?
