Author Topic: Headlight upgrade  (Read 5824 times)
Salty
  • Fleetwood
Re: Headlight upgrade
« Reply #1 on: 14 July 2006, 11:39:44 »
are the standard lights that bad that they need upgrading?
Not driven mine in the dark yet :-/
nixoro
  • Hitchin, Herts
« Reply #2 on: 14 July 2006, 11:45:05 »
The standard ones on mine are pretty good at the moment as they haven't turned yellow yet.
I would like to upgrade mine so I may go after these.
Cheers for the links. :-/
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #3 on: 14 July 2006, 11:45:37 »
IMO yes!
I hope they got better with the facelift.
I used to have a 96 2.0 CD spec, I actually drove a couple of times (accidentally), with full beam, on instead on dipped lights, and nobody flashed at me. :o
Elite now-a-days with xenons, now that is much better. :D
Salty
  • Fleetwood
« Reply #4 on: 14 July 2006, 11:47:37 »
I thought mine looked a bit foggy, so was considering a replacement but that's down the list a bit at the moment.
« Reply #5 on: 14 July 2006, 14:05:44 »
If they are a bit foggy then give them a rub down with fine wet and dry adn then polish them up with T-cut ......makes quite a difference.
The key thing about the above lights is that they are the later Halogen bulb based projector lights and not HID so they dont requrie a ballast pack or any mods to the wiring, the standard plugs for the lights, leveling motor etc all plug straight in.
Salty
  • Fleetwood
« Reply #6 on: 14 July 2006, 14:39:50 »
wet and dry sounds a fairly low cost option, may give it a go when I'm at home.  Might get some of the newer ones later.
dudester32
  • dundee
« Reply #7 on: 14 July 2006, 20:51:21 »
Any easy upgrade to the ealier omega lights has to be a good thing, my friend has a m reg cdx and the nightlights are terrible, that is unless he has something wrong with them, but i doubt it from what ive read previous, i will post him the link to this auction, thanks.
mr des
  • limerick, ireland
  • Doh
« Reply #8 on: 17 July 2006, 12:18:49 »
i got one of each as it failed nct (mot) on the reflector condition and i searched all local scrappies and only one light was any good so the other came mail order from a 99 facelift. when i went to get the beams set the guys swore they would never pass it because it had two totally different patterns, i argued that if both were set up right there could be no prob. sailed thru the nct after that and i think it rocks havin odd lights reminds me of the johnny cash tune "one piece at a time"
i want to shine in the eye of orion but i drove my sole through the black hole
