Author Topic: Auto to manual conversion?  (Read 4695 times)
The Barge Captain
« on: 18 July 2006, 14:00:04 »
If i was considering converting a 2.5 auto to a manual box, what would i need to be doing(other than buying a box, pedal box assembly and a gear lever assembly) Would i need to disconnect the autobox ecu & throw it onto ebay and would i need to replace the EM ecu? Is it worth the effort? This is based around a 97 tourer estate, so not worth a lot to start with. What do you think? Only considering this as a manual would probably burn less petrol
Salty
  • Fleetwood
Re: Auto to manual conversion?
« Reply #1 on: 18 July 2006, 14:14:19 »
Would it make enough difference in consumption to be worth the cost and effort?
« Last Edit: 18 July 2006, 14:14:56 by salty »
Big Rod
  • Fife, Scotland
« Reply #2 on: 18 July 2006, 14:18:40 »
Just go and buy a manual car in the first place!!!!
JM2PW!
If I have to explain you won't understand!
Martin_1962
« Reply #3 on: 18 July 2006, 14:20:15 »
A lot of work - also autobox ECU sort of talks to engine ECU and you will get errors on the MID
As to value - easier to buy a manual
« Reply #4 on: 18 July 2006, 17:10:39 »
Mid needs re-programming (or a wire shorting out) Engine loom needs a minor mod (ECU doesn't need touching) you need a spiggot bearing and dual mass fly wheel (auto has a pressure plate). Prop is different I think.....
Different brake fluid header tank, clutch master cylinder required.......big job realy.
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 18 July 2006, 21:54:38 »
yea as mark says quite a big job but poss  ;) have done two in my time not easy but doable if you are any good on the spanners  ;)
« Reply #6 on: 18 July 2006, 23:47:01 »
if DTM said its a big job, i must be a HUGE job.
The ones he says are easy 5 mins take the rest of us most of the day to do!! lol
As for the cost saving issues? Bah nothing in it tbh.
I only average about 2mpg more than my dads car, both facelift 2.2's
His averages around 32mpg (auto) , mine does around 34.
« Last Edit: 18 July 2006, 23:47:41 by tunnie »
cipher
  • Derby
« Reply #7 on: 20 July 2006, 00:16:13 »
Doesn't the Engine have an additional Needle Bearing on the crank if in Manual Trim?
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
« Reply #8 on: 20 July 2006, 20:44:33 »
Yep, thats the spigot bearing....
