Author Topic: Cruise Control Upgrade  (Read 12140 times)
Big Rod
  • Fife, Scotland
Re: Cruise Control Upgrade
« Reply #15 on: 21 July 2006, 14:02:44 »
Its in the actuator box......
Alrighty then!!  :-[
If I have to explain you won't understand!
nixoro
  • Hitchin, Herts
« Reply #16 on: 21 July 2006, 14:03:38 »
Would the Elite cruise control setup work on a 2.0 only not seen many 2.0 cdx about being broken with the cruise on it.
« Reply #17 on: 21 July 2006, 14:07:22 »
They are not engine or trim specific (CDx and Elite had it as standard)....so any actuator based cruise system (which is most of them) will work......even the one off a Vectra will work but the cable may need changing!
nixoro
  • Hitchin, Herts
« Reply #18 on: 21 July 2006, 14:11:14 »
Cheers for the response Marks DTM
Shall keep an eye out for an Elite thats being broken up.
With any luck I will be able to get all the parts needed.
JasonH
« Reply #19 on: 21 July 2006, 16:56:44 »
If you get a 2.0 cruise unit then I believe it will need reprogramming if used on a V6 and vice versa. It's to do with the engine speed signal. The cruise will actually work, but the lower speed limit for cruise will be wrong.
The cable is different for the 3.0, 2.5, Vectra 2.5 and 2.0 so try to get the right cable. They cost about £50 from the dealer.
The cruise actuator is the same across quite a few Vx models.
I have a long commute and use cruise every day. I find it excellent and it allows you to stretch your legs.
nixoro
  • Hitchin, Herts
« Reply #20 on: 21 July 2006, 17:01:31 »
Cheers for the response JasonH
Shall keep an eye out and try to get the right parts if not possible shall just go direct to Vx and get the right length cable.
JasonH
« Reply #21 on: 21 July 2006, 17:01:39 »
Oh and watch Ebay. A complete cruise kit can be had from about £40 to £70.
But the clutch switch (if you have a manual) is a pain. They're quite rare secondhand and cost about £19 from the dealer. You might also need a 4 wire brake switch, another £13 or so.
nixoro
  • Hitchin, Herts
« Reply #22 on: 21 July 2006, 17:05:15 »
Shall definately keep an eye out on ebay for a kit, I maybe lucky.
Clutch switch heard a few people mention these, may just go to the dealer when the time comes.
Brake switch again maybe lucky if not dealer it will be.
Has anyone got any pictures or part numbers of the Clutch switch and Brake switch for future reference.
Cheers in advance
Roy
JasonH
« Reply #23 on: 21 July 2006, 17:22:50 »
                                               Part no:      Approx price (excl VAT)
Brake switch (non-cruise) (newer Omegas)      9149765
Brake switch for cruise (newer Omegas)      9149766       £12
E-clip for cruise cable (10 off)             11051532      £0.40
Brake switch is fitted to Y22XE, X20DTH, Y26SE, Y32SE, Y22DTH, Y25TD, X20SE, X20XEV, X25XE,X30XE with cruise. Not used on any other Vauxhalls.
Cruise cable X25XE (IDENT KK)            25140751      £48.15
Cruise cable X30XE(IDENT DZ)            25312986
Stalk                          9181011      Vectra, Omega, Sintra
Clutch switch                   90458543      Omega to S1221920
Clutch switch                    90569685       Vectra
Clutch switch                  90492444      Corsa, Astra, Zafira
Clutch switch (later Omegas)            90494519      £19.60
Vectra clutch switch will fit later Omegas (apparently).
Omega and Vectra clutch switches:
Omega is bigger, but connectors are the same.
« Last Edit: 21 July 2006, 17:26:23 by JasonH »
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #24 on: 21 July 2006, 18:43:34 »
i use mine all the time, A roads and motorway....
I find i can get at least 5mpg more at 75mph when cruise is on, and it is more relaxing.....
In the process of fitting cruise to my Mk2 cav
« Reply #25 on: 21 July 2006, 20:44:16 »
yup, agree with Marks_DTM on this one, wouldn't whant to be without it. Great for keeping to 30mph in those long villages....
