Author Topic: LED Bulbs  (Read 10069 times)
philayl
  • Wirral, Merseyide
LED Bulbs
« on: 20 July 2006, 19:06:23 »
Hi all, nice to be back among you, took a while to find where you were. Can anyone help with a problem I have, I would like to fit LED stop/tail bulbs, also LED indicator bulbs. The problem is they (stop/tail, not fitted indicator yet) show up on the display as failed bulbs, so I am told I need to fit a load resistor for each bulb but the bulb holder is for the stop/tail lights, indicators and reversing lights. A plug with four wires connects to the bulb holder assembly. I am now unsure if it is o.k. to connect the load resitor to a wire supplying the power to all three bulbs. Can you advise if this is alright, and can I just have one load resitor and change all three bulbs to LED?
Re: LED Bulbs
« Reply #1 on: 20 July 2006, 19:17:53 »
Its gonna depend on the load resistor they supplied as to whether 1 per bulb or 1 per circuit. The vendor should be able to clarify.
STMO123
Re: LED Bulbs
« Reply #2 on: 20 July 2006, 19:40:14 »
Now heres a surprise...I never knew you had to fit load resistors when using LED's, and I've looked at them on ebay loads of times. Funny the sellers never mention that. I wonder how many people buy these things and then just cant be bothered with the hassle.
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #3 on: 20 July 2006, 19:41:31 »
Hi, he says one per bulb, but this is not possible with the wiring as it is, e.g one plug for all the bulbs in the bulb holder assembly, is there another way round it?
Re: LED Bulbs
« Reply #4 on: 20 July 2006, 19:41:59 »
Any car that has blown bulb detection, as many Omegas do, will require the load resistors so the LEDs (combined with load resistor) pull same current as traditional bulb
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #5 on: 20 July 2006, 19:44:09 »
Hi STMO123, they do work o.k. on the stop/tail anyway, but show up on the MFD as blown bulbs, I believe the indicators flash rapidly without the load resistors.
cipher
  • Derby
Re: LED Bulbs
« Reply #6 on: 20 July 2006, 20:21:25 »
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #7 on: 20 July 2006, 20:35:17 »
Hi, these are what I have bought, but as I said before the wires to the indicators and stop/tail lights are not seperate, they run off one power supply, and you are supposed to fit one per bulb, which is not possible, so where do you fit the load resistors.    p.s. I paid £5.99 for a pair of them from C.M.S. Supplies on ebay, this chap wants £9.99!
Liam
Re: LED Bulbs
« Reply #8 on: 20 July 2006, 20:54:30 »
Hi there,
Dont quite get what your problem is - there are separate feeds to each different light.  There has to be or they wouldn't be able to operate independantly!  They will share a common ground but that wont stop you wiring resistors accross each bulb individually.  If you need the wire colours i can get them off me diagrams for you (or do you have a haynes?), but it ought to be easy to see which wires feed which lights (he says without having a look at the car...).
Liam
Re: LED Bulbs
« Reply #9 on: 20 July 2006, 21:09:53 »
Probably easier to play around with the signals to the mid....
pin17 is the head light fault input
pin18 is the brake light fault input.
By disconnecting the feed wire to the mid and connecting it to either 12V or 0V (I dont know which as I havn't tried it) you would be effectively permanently disabling the error message.
« Last Edit: 20 July 2006, 21:10:36 by Mark »
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #10 on: 21 July 2006, 17:07:02 »
Hi Liam, have been out to have another look at the rear light clusters, I can now tell you exactly what my problem is, I am thick, stupid, married and thoroughly ashamed of myself. I stupidly thought the brown wire was the live feed, when it is the earth, something you said woke me up, "There are seperate feeds to each light....... or they would'nt work independantly", obvious when you see it written down! Anyway have fitted the load resistor to the brake light live feed and to the common groung wire(brown one, doh!) Only problem is the tail lights show as blown, so I will have to order two more load resistors and do the same with them. p.s. the brake lights no longer show as blown, at least I got something right eh! Thanks for all your help lads.
« Last Edit: 21 July 2006, 17:07:47 by philayl »
nixoro
  • Hitchin, Herts
Re: LED Bulbs
« Reply #11 on: 21 July 2006, 17:09:10 »
Sounds interesting the LED conversion, is there any chance you could do a How2 guide. :)
Cheers
Roy
Re: LED Bulbs
« Reply #12 on: 21 July 2006, 18:14:11 »
I think fitting load resistors is bad.....disonnect the mid signals rather than cooking a set of resistors in the light cluster area.
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #13 on: 21 July 2006, 18:51:30 »
Hi Mark, I hear what you are saying, but I have no idea how to disconnect the MID signals, and if it means removing the MID unit I don't feel confident enough to do it. I will however keep a close eye on the arrangement for a while to see if any problems occur.
philayl
  • Wirral, Merseyide
Re: LED Bulbs
« Reply #14 on: 21 July 2006, 18:57:02 »
Cheers
Roy
Hi Roy, if this works with no problems, I would be only to happy to do a How2. I have only done the brake light side of the stop\tail at the moment. I have just ordered two more load resistors to do the tail light side. Will let you know if it works o.k. If there are no overheating problems either with the resistors or the stop/tail assembly, and the bulbs don't blow, I will report back after fitting the next two resistors.
« Last Edit: 21 July 2006, 18:57:53 by philayl »
