Author Topic: Gaskets and silicon sealer  (Read 3987 times)
Martin_1962
« on: 18 July 2006, 22:18:35 »
Has anyone ever tried this, I read about it years ago and I used the technique on my old Sunbeam as one end manifold stud had sheared - it was fine - only had to change gasket when lifting the head.
I used it on the CD when selling due to a broken stud and it worked then.
SO what are the opinions?
JasonH
Re: Gaskets and silicon sealer
« Reply #1 on: 19 July 2006, 11:02:22 »
I presume you proposing silicon sealant on the inlet manifold rather than the exhaust manifold!
Not a great fix, but I suspect it would work.
nixoro
  • Hitchin, Herts
« Reply #2 on: 19 July 2006, 11:08:02 »
Never really thought of using silicon sealant, I just used the usual sealant when I did my manifold gasket.
Recommended at the parts desk.
Seems to be ok even with a missing stud.
HTH
« Last Edit: 19 July 2006, 11:58:04 by nixoro »
« Reply #3 on: 19 July 2006, 11:28:18 »
Sealent on the manifold.....what sealent.....
Be careful with silicon sealent as it can attack some metals (i.e. copper).....
Martin_1962
« Reply #4 on: 19 July 2006, 11:56:00 »
Well it worked for the 2.0CD exhaust and the manifold gasket for the Sunbeam - read it somewhere - I'll have a search tonight
JasonH
« Reply #5 on: 22 July 2006, 17:49:44 »
Tell me more.
Had a go at replacing my passenger side exhaust manifold gasket today (without removing the engine) found one stud broken off and then had to call a halt when one other stud refused to budge and eventually rounded off.
Here's the cheeky little blighter:
As I'm now going to need the full engine out treatment (which I can't do myself) silicon sealant seems most attractive.
Did you fill the stud hole?
Did you put a bead round the edge?
Or did you lift the manifold away and use the silicon like a gasket?
Martin_1962
« Reply #6 on: 22 July 2006, 18:25:21 »
I put a thin bead around each hole both sides of the gasket. Then quickly bolted down before it dried - don't know how long it will last
JasonH
« Reply #7 on: 22 July 2006, 20:10:38 »
OK - thanks.
In my case I can't get the manifold off....I've also just read that silicon sealant can poison the lamba sensors - so not sounding quite so good now  :(
