Author Topic: Misfire  (Read 10012 times)
cipher
  • Derby
Misfire
« on: 22 July 2006, 01:20:36 »
Well,
I thought I had sorted the misfire the other day, but its now back.
Car again, has no power, and needs to be in Sport mode to get anywhere when above 40mph, or a slight incline.
Have just ordered a DIS pack, Well, I say ordered, picked it up from eBay (Thanks Mark) for 99p  ;)
So, will fit this and see how it goes.
Had some of the plugs out today, to check. 4 of them out, two inaccesible. Couldn't get No1 Throttle cable mounting plate and valve in the way (Dont have any E-Torx sockets, so no chance), and No6, as didn't have time to take the wipers off.
So, Plugs looked okay, Not cracked or anything. Thionking of repalcing them anyway, how much for 6 on Trade Club?
Any other thoughts if not cured by this and DIS pack?
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
Admin
Re: Misfire
« Reply #1 on: 22 July 2006, 09:06:26 »
Ben,
Set of 6 plugs should be around £15, let me know and I'll pick you up a set.
I can lend you the sockets no probs (would offer to assist, but after today I will be totally bogged down with work!  :( )
Oh, and 99p for a DIS pack?? Jammy [smiley=lipsrsealed.gif]er  ;D
The Administrator.
Martin_1962
Re: Misfire
« Reply #2 on: 22 July 2006, 17:16:31 »
E sockets are available from Halfrauds at not too bad a price
I have 3 or 4 including an accidental duplicate
JasonH
Re: Misfire
« Reply #3 on: 22 July 2006, 17:33:36 »
With a universal joint and a short extension piece and spark plug socket I've managed to remove my plugs twice.
Didn't need to disturb the throttle mounting and did 1,3,5 without doing much to anything.
2,4,6 require the ICV removal and moving of the wiring tray but not the scuttle. 6 is a pig though.
cipher
  • Derby
Re: Misfire
« Reply #4 on: 22 July 2006, 17:49:16 »
My plug socket is a bar that is about 10" long, so it doesn't bend, guess I could try the normal socket with an extension bar though.
Okay,
Will see what the replacement DIS pack flasgs up, and take it from there.
Car is due a service, but just want to get it running right first.
PM For Details
Re: Misfire
« Reply #5 on: 22 July 2006, 17:55:09 »
I've got a feeling its the DIS pack - change that and see what happens then....
cipher
  • Derby
Re: Misfire
« Reply #6 on: 22 July 2006, 18:37:36 »
That was Marks thought too as it seems to be down on 2 cylinders
PM For Details
Re: Misfire
« Reply #7 on: 22 July 2006, 18:40:01 »
down on 2 cylinders, most likely dis...
i hear its a pig to change :(
cipher
  • Derby
Re: Misfire
« Reply #8 on: 22 July 2006, 19:20:07 »
Thanks.....
PM For Details
Re: Misfire
« Reply #9 on: 22 July 2006, 22:08:58 »
30 mins using the DTM method.....
Re: Misfire
« Reply #10 on: 22 July 2006, 22:12:14 »
Are you going to write up the DTM method?
cipher
  • Derby
Re: Misfire
« Reply #11 on: 22 July 2006, 22:16:32 »
Yes, Please do, as this looks like a pig of a job, But then so did the rocker gaskets, and that looked (i did say Looked!) easy.
Another question Mark, What is the specified Torque of the DIS pack mounting bolts (Are they 4xE12)?
Many thanks
PM For Details
Re: Misfire
« Reply #12 on: 23 July 2006, 10:03:07 »
Not sure on the size to be honest....think they are 4 off E10.
The DTM method involves removal of the scuttle cover and reaching over the back of the engine (easier with breathers disconnected etc and knee resting on the slam panel), using a suitable ratchet plus socket plus small extension for the verticle ones (as per cyphers) or a flexi screw driver drive for the horizontal ones..
I then ease it across the back of the engine to the drivers side (very tight fit but, it can be done) to remove it.
Refit is reverse of removal.....
cipher
  • Derby
Re: Misfire
« Reply #13 on: 23 July 2006, 10:06:52 »
Mark,
Is my DIS pack mounted vertically? (ie two columns of three, rather horizontally two rows of three?)
Sorry, just a little confused...
PM For Details
Re: Misfire
« Reply #14 on: 23 July 2006, 10:08:01 »
I think we want a full blown How2, complete with pictures  ;D
