Author Topic: Climate sensor cleaning  (Read 3280 times)
P_Russell
  • Rushden, Northants
« on: 27 July 2006, 14:23:29 »
I'm suspecting that my climate sensors aren't working properly - auto mode is pretty useless but when in manual all works fine (4 degees C, or 277K for us  :( chemists.....)
3 questions:
1) How do I remove the control panel to get to the sensor in the centre - I can only find a how to for a facelift?
2) Where is the footwell sensor located?
3) Will this stop the wife moaning?
...OK, so I already know the 3rd question is not possible, but I live in hope.........
« Last Edit: 27 July 2006, 14:27:13 by P_Russell »
If it's stuck, force it.  If it breaks, it needed replacing anyway........
Taxi_Driver
Re: Climate sensor cleaning
« Reply #1 on: 27 July 2006, 18:18:28 »
I was about to say you must have a facelift! ....but then noticed you commented about only being able to find a howto on a facelift......so i assume you have a prefacelift.
I expect TheBoy will be able to advise if you can read climate faults with a tech2...as this might be the way to go before pulling your dash apart.
Something i was going to ask.....and not trying to hijack your thread...and might help your problem...experts will prolly know.....is it possible on facelifts (or prefacelifts) to hit a combination of buttons on the climate for it to flash up error codes.
I can do this on my merc.......just wondered if its maybe the same on vx's??
Cheers
Dave
« Reply #2 on: 27 July 2006, 18:24:40 »
Tech1/Tech2 so diagnose climate issues - no flash codes.
I'm sure there is a climate panel bulb change guide here or on other site, that should give you all you need. Or a quick phone call you brother ;)
« Reply #3 on: 27 July 2006, 22:06:14 »
Get teh hoover on the climate panel sensor grill.
The other sensors are on the side vent ducts...
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 28 July 2006, 00:16:04 »
Is the little sampling fan in the climate panel running?
