Author Topic: PAPERCLIP TEST  (Read 11832 times)
STMO123
Re: PAPERCLIP TEST
« Reply #15 on: 31 July 2006, 21:19:54 »
Read the thread linked to above...
v6 is motronic
Mines moronic ;D
Re: PAPERCLIP TEST
« Reply #16 on: 31 July 2006, 21:21:13 »
Correct, it will only work on the older engines, the new ones need a fault code reader :(
Re: PAPERCLIP TEST
« Reply #17 on: 31 July 2006, 21:26:40 »
Knock sensor 1 is on cylinder 1 which is the drivers side.
How does it drive, if its knock sensor then you get no ECU light until you first rev it and then it runs very flat (low on pwoer)
Check the wiring has not got caught in the aux belt and damaged
STMO123
Re: PAPERCLIP TEST
« Reply #18 on: 31 July 2006, 21:30:53 »
Drives absolutely fine Mark. No loss of power and EM light on permanently.
Re: PAPERCLIP TEST
« Reply #19 on: 31 July 2006, 21:32:23 »
Does it ever cut out or struggle to start?
STMO123
Re: PAPERCLIP TEST
« Reply #20 on: 31 July 2006, 21:34:20 »
No, everything really does seem normal. Got 31mpg to Liverpool and back yesterday and I didn't hang about ;)
Re: PAPERCLIP TEST
« Reply #21 on: 31 July 2006, 21:36:15 »
Its worth giving the knock sensor plug a good clean then......usualy by the EGR valve or on a bracket on the cam cover, simply follow the wire up the left hand side cam belt cover edge....
STMO123
Re: PAPERCLIP TEST
« Reply #22 on: 31 July 2006, 21:39:26 »
I'll do that tomorrow. Its dark and p******g down at the moment.
The Boy and Mark--Thanks--I am really grateful for your help on this one. [smiley=thumbsup.gif]
Re: PAPERCLIP TEST
« Reply #23 on: 31 July 2006, 21:42:34 »
Not a problem an if it persists you will have to make a 45 minute drive south some time...!
STMO123
Re: PAPERCLIP TEST
« Reply #24 on: 31 July 2006, 21:46:03 »
Please dont tempt me Mark. There is nothing more gratifying than seeing someone who knows what they are doing, and is honest, looking at your car....or phone...or telly
