Author Topic: Spark plugs V6 '97 - are they the right ones!  (Read 5054 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 28 July 2006, 22:19:24 »
Had an interesting experience at the Opel dealer in Granada town here in Spain.
I would like six spark plugs for this vehicle please? Here is the Spanish log book- same details as a UK car which it was prior to export and re registration.
After a very, very long search he came back with 6 plugs and said "I think these are the ones, if they aren't bring em back!" (Most Omegas in Spain are diesels) £21 for the six.
They came in Opel boxes with a bar code 12 14 000 and on the other side 9195109 on it. The end of the box has 0 242 229 627 712 755 (09 .99) the other end has 1#9195109  GR.02.270  12 14 000
On the 10 mm plug itself it says  FLR8LDCU GERMANY 681 . They have a brass top, 4 blue bands and GM 000 in blue. They also have twin electrodes.
While I wait for my ebay flexible 10 mm spark plug socket to come from the Uk, can anyone confirm these are the right ones please?
Re: Spark plugs V6 '97 - are they the right ones!
« Reply #1 on: 28 July 2006, 22:23:02 »
Hmmmm....part code should be 91132006
Varche
    • Golf Estate
« Reply #2 on: 28 July 2006, 22:38:29 »
So which of all those numbers is the part number then!?
« Reply #3 on: 28 July 2006, 22:44:00 »
If its post 08018689 engine number then its the right part number....
Varche
    • Golf Estate
« Reply #4 on: 28 July 2006, 22:58:14 »
08226271 , Thats Ok then. One less thing to worry about.
many thanks.
Markjay
  • London
« Reply #5 on: 29 July 2006, 01:16:24 »
GM/Vauxhall plugs are mage by Bosch.
FLR8LDCU is the correct Bosch part number for X25XE and X30XE. This is the twin-electrode plug originally fitted to the 2.5 and 3.0 engines. Vauxhall quote change at 40,000 miles / 4 years.
FGR8KQE0 is the Bosch part number for Y26SE and Y32SE. This is a four-electrode plug originally fitted to the 2.6 and 3.2 engines. It can be retro-fitted to the 2.5 and 3.0. Vauxhall quote change at 80,000 miles / 8 years.
So it would seem that the plugs you have are the correct ones for your car.
HTH.
Alas, no more Omegas....
infinity1
  • sunny south east
« Reply #6 on: 09 August 2006, 20:05:20 »
HTH.
are you saying mark that either of the plugs can be used on my 97 3lt elite????
« Last Edit: 09 August 2006, 20:05:48 by infinity1 »
mechanics? not me at all mate...
« Reply #7 on: 09 August 2006, 20:52:00 »
HTH.
I've had the ('wrong') 4 electrode plugs in my 99 3.0 Elite for the last years or so, if that's any help.
« Last Edit: 09 August 2006, 20:52:51 by Andy_B »
Markjay
  • London
« Reply #8 on: 11 August 2006, 00:17:10 »
The 2.6/3.2 engines have modified emission control and lower compression ratio, and they will need the four-electrode spark plug and shouldn't be fitted with the older two-electrode type.
But the newer four-electrode spark plugs can be retro-fitted to earlier 2.5/3.0 engines as replacement to the original two-electrode ones.
However, the only advantage of using four-electrode spark plugs in the older 2.5/3.0 engines is the longer service life, there will be no noticeable difference is performance or fuel economy. But since I wouldn't recommend leaving the plugs in the engine for 80k anyway (I changed my four-electrode ones at 40k) - in practical terms there is no need to bother about getting four-electrode plugs for the older 2.5/3.0 engines.
Incidentally, the longer service life is the result of doubling the number of electrodes - since only one electrode actually fires at any given point of time, the theory is that the wear is halved when using a four electrode plug instead of two-electrodes...
« Reply #9 on: 11 August 2006, 07:17:56 »
However, the only advantage of using four-electrode spark plugs in the older 2.5/3.0 engines is the longer service life,  .....
and they're cheaper  :)
