Author Topic: Autobox slipping / losing drive  (Read 3505 times)
The Barge Captain
« on: 10 August 2006, 15:49:59 »
Does anybody have any thoughts on a autobox that starts off ok, then loses drive after a bit, but if stopped for a while regains its drive?
I'm thinking lack of ATF.
How much would i be looking at for a replacement box, and what is the difference between an A25 and A35 box (to fit a 2.5)
Re: Autobox slipping / losing drive
« Reply #1 on: 10 August 2006, 17:17:19 »
If you repalce the box then its worth fitting an AR35 as it is stronger.
Sounds like oil lack but, worth changing it anyway as it always helps.
The Barge Captain
« Reply #2 on: 11 August 2006, 09:33:39 »
Any difference in ratios between AR25 and AR35?
Admin
« Reply #3 on: 11 August 2006, 13:03:37 »
Slight difference, but nothing noticable.
As the boss says, change the fluid first. It is much easier and less time consuming!
The Administrator.
