Author Topic: Brakes pulling to left  (Read 2513 times)
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
« on: 13 August 2006, 20:48:21 »
Now then guys im in need of a little advise on this one!!
When i brake the car pulls to the left and i have to compensate by steering to the right.
Ive changed all steering components as they were little worn. Track ends, idler, centre rod assembly have all been changed. The lower arms and front shockers were all changed last year at MOT.
Also changed all brakes and replaced fluid.
Any ideas?? Im thinking it may be the strut top mounts which are knackered but am open to other suggestions to check.
Cheers.
« Last Edit: 13 August 2006, 20:49:41 by PhilCavSRi130 »
Re: Brakes pulling to left
« Reply #1 on: 13 August 2006, 20:53:42 »
My estate was doing this....it was due to the wishbone bushes, although not worn, one had been fitted the wrong way round into the wishbone.....so do check the bushes (for damage and orientation!)
PhilCavSRi130
  • GRIFFIN POWER!!
« Reply #2 on: 13 August 2006, 21:12:51 »
Cheers Mark will have a look as its getting on my nerves. i hadn't driven it for a few weeks and forgot about till i braked first time...
« Reply #3 on: 14 August 2006, 01:17:29 »
Nearly always wishbones in my experience!
mr des
  • limerick, ireland
  • Doh
« Reply #4 on: 14 August 2006, 13:15:59 »
if there is no play in any steering or suspension components is is either a duff caliper or the camber is incorrectly set up prob the latter there is a thread on here on 4 wheel geometry
i want to shine in the eye of orion but i drove my sole through the black hole
