Author Topic: Prefacelift Console Removal  (Read 8701 times)
« on: 17 August 2006, 22:02:39 »
As above, how do you get it out?
Got my facelift one out easy as pie, the screw beind the ash tray and the 2 behind the headunit then it just unclips.
But how do you get the pre-facelift ones out?
Re: Prefacelift Console Removal
« Reply #1 on: 17 August 2006, 22:04:27 »
check faq/maintainence sections - i think there is something there...
« Reply #2 on: 17 August 2006, 22:08:40 »
Climate or non-climate?
« Reply #3 on: 17 August 2006, 22:09:56 »
looking at photos, non ecc
« Reply #4 on: 17 August 2006, 22:11:25 »
Radio out, to screws behind the ashtray, pull the heat, fan speed and direction control nobs of and you will find four more screw.....remove these and jobs a good un.
« Reply #5 on: 17 August 2006, 22:12:20 »
Non-climate.
Checked the maintance guides, got JayW's facelift removal, and MarkDTM's dash pannel (speed, rev, mid ect..)
I want to remove the heater control / dash buttons ect...
I want to see if i can get the loom from a scrappy one tomorow.
Also last time at the scrappy i could not remove the headunit... it came out about half way then just jammed.
« Reply #6 on: 17 August 2006, 22:14:00 »
Ahh did't relise the control knobs came off (some expert me  ::)) - I am used to facelifts  :P
Removing the radio, i got one out half way but then jammed, i can see the 4 tiny allen key type screws on the front. I got them loose and almost got the unit out...
« Reply #7 on: 17 August 2006, 22:18:57 »
the grub screws on radio? remove them, and use removal keys to remove radio!
« Reply #8 on: 17 August 2006, 22:32:01 »
Yep got the grub screws off - and i managed to get the radio almost out.
The keys just give you more leverage to wiggle the radio out?
Unfortunely don't have ane removal keys. (only double din) Screw drivers did't seam to make it budge.
mr des
  • limerick, ireland
  • Doh
« Reply #9 on: 17 August 2006, 22:42:59 »
no the keys engage in the locks and spread em to allow you to remove the radio brute force as always can be substituted for correct tools
i want to shine in the eye of orion but i drove my sole through the black hole
« Reply #10 on: 17 August 2006, 22:44:43 »
*reaches for the birmingham hammer....*
STMO123
« Reply #11 on: 17 August 2006, 22:47:39 »
Or as we used to use in Liverpool, a bent metal coathanger ;)
« Reply #12 on: 17 August 2006, 22:49:31 »
Ive used an old metal coat hanger cut in two and shaped. Worked a treat
Bo Bo
  • Coventry
« Reply #13 on: 17 August 2006, 22:57:45 »
Part of the cage might be sticking out?
« Reply #14 on: 17 August 2006, 23:04:03 »
Good idea, got a few kicking around...
