Author Topic: Auxillary Belt  (Read 4641 times)
Salty
  • Fleetwood
Auxillary Belt
« on: 19 August 2006, 21:06:05 »
When changing the auxillary belt is it worthwhile changing the tensioner at the same time?
I'm going to do the cambelt soon and the aux belt looks like the rubber is beginning to crack so I was going to replace it at the same time.
Matchless
  • Nottingham
    • A white van
Re: Auxillary Belt
« Reply #1 on: 19 August 2006, 21:10:33 »
Check the tensioner pulley for play or roughness in the bearings, replace the pulley if bad but otherwise gently prise out the rubber seal and force a small amount of grease into the bearing then replace the seal.
Salty
  • Fleetwood
Re: Auxillary Belt
« Reply #2 on: 19 August 2006, 21:21:43 »
I'll check that when I do the job. I'm just compiling a list of parts I'll need.
Robin Hood
  • Nottingham
Re: Auxillary Belt
« Reply #3 on: 19 August 2006, 22:43:52 »
Just finished the Cambelt & Water Pump DVD which includes Mark testing and repacking the tensioner with grease, as described by Pete.
Re: Auxillary Belt
« Reply #4 on: 19 August 2006, 23:35:05 »
SKF (or whoever) must have been tight with the grease. Had to do the same with mine cos it was as dry as a witches t*t too!
Salty
  • Fleetwood
Re: Auxillary Belt
« Reply #5 on: 20 August 2006, 07:33:31 »
Any chance of a copy?
Robin Hood
  • Nottingham
Re: Auxillary Belt
« Reply #6 on: 20 August 2006, 14:13:01 »
No problem, PM me with your address.
