Author Topic: Compression Testing V6  (Read 8243 times)
Allenm
  • Milton Keynes
« on: 22 August 2006, 11:29:14 »
I need to test the compression on my 2.5 V6 to see if any valves got bent when the cambelt sipped, but am not sure on how.
Questions..
1.  Will this do the job ?
http://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10151&productId=199553&categoryId=31477
2.  How do I actually perform the test?  (only ever used one on a single pot motorbike)
3.  How the hell do I get the the passenger side bank??? :o
Many thanks
Merv
Matchless
  • Nottingham
    • A white van
Re: Compression Testing V6
« Reply #1 on: 22 August 2006, 11:43:37 »
That gauge should be fine.
Unbolt the cable tray on the passenger side to improve access.
All plugs out.
Unplug the injection relays (purple ones in ecu box) to stop injectors.
Hold throttle wide open then crank for 2-3 seconds.
Markjay
  • London
« Reply #2 on: 22 August 2006, 13:36:05 »
The access is the same as for changing spark plugs.
The testing method is as above, but also make sure that the HT leads are insulated and tucked safely away from any part of the body to avoid a spark.
The easiest is a compression tester that has a screw fitting as opposed to a rubber cone, the screw fitting allows you to do this test yourself without the need for a helper.
(With the rubber cone type, you can still short-circuit the starter motor and do this as a one-man job, but on automatic cars this can be risky because the starter motor short-circuit method by-passes the gear selecor inhibitor so the car could be started in gear by mistake - though obviosuly not while while the plugs are out)
Then carry-out a dry and wet test on any low-compression cylinder by adding a couple of spoonful of engine oil through the spark plug hole - if the problem is due to compression rings' wear, the oil will boost the compression on re-testing, if the low compression is due to leaky valves (or HG) then the added oil will have no effect on the compression which will remain low on the re-testing.
Alas, no more Omegas....
Allenm
  • Milton Keynes
« Reply #3 on: 22 August 2006, 14:04:23 »
Thanks for the replies.  I've just gone and bought the one from halfords shown in the link above.
One slight query.. The instructions of the tester say to remove only the spark plug on the pot being tested then replace before removing the next etc.  Is this wrong? I suspect it is but just want to confirm I should remove all the plugs and then just test each pot in turn without replacing the plugs.
Finally ( ::)) is there an easy way to disable the spark to all six leads?  a fuse or relay somewhere?
Cheers
Merv
Markjay
  • London
« Reply #4 on: 22 August 2006, 14:12:41 »
...One slight query.. The instructions of the tester say to remove only the spark plug on the pot being tested then replace before removing the next etc.  Is this wrong? I suspect it is but just want to confirm I should remove all the plugs and then just test each pot in turn without replacing the plugs...
Interesting... I always did the compression test with all plugs removed, the engine cranks much easier this way and there is less strain on the battery. Not sure why they say to do this one at a time - I can't see how this could affect the compression reading for the cylinder tested, perhaps they wanted to prevent petrol from being spitted-out through the plug holes (which will not be the case anyway if you remove the injectors relay)?
Markjay
  • London
« Reply #5 on: 22 August 2006, 14:14:51 »
...is there an easy way to disable the spark to all six leads?  a fuse or relay somewhere?...
I would say disconnect the multi-plug feeding the DIS pack, though I am not sure how easy is the access to it. Alternatively, just tie them together with a cable tie and make sure they are well out of the way.
« Reply #6 on: 22 August 2006, 14:25:34 »
Pull the fuses that feed Motronic??
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 22 August 2006, 14:25:36 »
If you pull the two purple relays it will inhibit both fuel injection and spark.
Allenm
  • Milton Keynes
« Reply #8 on: 22 August 2006, 14:28:38 »
Cheers guys,  Will give it a go in a while and post the results.
Allenm
  • Milton Keynes
« Reply #9 on: 22 August 2006, 15:54:04 »
Quick Check..
What is this, and will having disconnected it affect testing the compression?
« Reply #10 on: 22 August 2006, 15:55:55 »
Idle valve and no it wont.....
« Reply #11 on: 22 August 2006, 15:56:16 »
Thats ICV (Idle Control Valve) - it won't affect compression test, but remember to reconnect when done, as the car will run like a sack of shit...
« Reply #12 on: 22 August 2006, 15:56:59 »
bugger, mark beat me, and the word censor doesn't like s h i t.
« Reply #13 on: 22 August 2006, 15:58:27 »
Word censor fixed for that word (which isnt a bad one in my book!)
« Reply #14 on: 22 August 2006, 16:02:48 »
Thats better - my wording above didn't make sense when it swaps words!
