Author Topic: Heated Mirrors  (Read 3690 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Heated Mirrors
« on: 21 August 2006, 19:29:56 »
Mirrors on my Omega are electric, guessing all of them are?  But are they heated?
Do they heat up in relation to turning the rear screen heater on?  Or should there be a little orange LED & push switch on the mirror adjustment switch?  (all it has is a left/right mirror selection switch & joystick)
The drivers mirror does have a heater sign imprinted on the glass, but the passenger doesnt.
If it doesnt have heated mirrors, is it then just a case of fitting a different switch?
Humbugs...
Paul M
  • Edinburgh
Re: Heated Mirrors
« Reply #1 on: 21 August 2006, 20:35:20 »
They come on with the rear screen heater, and only the driver's side has the symbol but both are heated.
Re: Heated Mirrors
« Reply #2 on: 21 August 2006, 21:08:22 »
Thats right they do come on with the rear screen heater and they are both heated with just the drivers side mirror on  ;)
Re: Heated Mirrors
« Reply #3 on: 21 August 2006, 21:15:35 »
Not uncommon for the terminals behind the mirror to corrode badly. Also the heater element sometimes fails.
Liam
Re: Heated Mirrors
« Reply #4 on: 22 August 2006, 23:36:43 »
Out of interest what is that orange LED that i sometimes see on omega mirror switches??  Mine doesn't have it.
Liam
PaulW
Re: Heated Mirrors
« Reply #5 on: 23 August 2006, 07:58:21 »
Liam
Thats the LED I'm talking about, its not on mine...
On the corsa, you'd press a little button next to the LED, which would then turn the heated mirrors on, and while they are on the light would illuminate...
but if whats said is true, then maybe they had new switch from the scrappy fitted, as I know the joystick can and does fail quite common...
Humbugs...
Matchless
  • Nottingham
    • A white van
Re: Heated Mirrors
« Reply #6 on: 23 August 2006, 09:58:38 »
On the Omega the led comes on when you switch on the rear window heater which also switches on the mirror heaters.
nixoro
  • Hitchin, Herts
Re: Heated Mirrors
« Reply #7 on: 23 August 2006, 10:02:16 »
This is what mine does. :)
Re: Heated Mirrors
« Reply #8 on: 23 August 2006, 10:03:03 »
The LED only exists on earlier Omegas...
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
Re: Heated Mirrors
« Reply #9 on: 23 August 2006, 15:07:46 »
My Cavalier has the LED tell tale for the heated mirrors, but my Omega does not.  Anyway, as other have said, they come on with the heated rear screen which, by the way, is timed and switches itself off after 10 minutes or so.  A great bit of thinking I reckon!
Just like other things like the one touch windows, pulling the headlight switch out for interior illumination etc...  Only my opinion...................
