Radiator Problems
Started by nixoro, 07 August 2006, 09:57:52
nixoro
#15
I know I have said Gen Vx would be the way to go but I have just been searching online and found a website that does Radiators for my Omega for £93.03 ideally I need to get it done ASAP
Here is the site www.adrad.co.uk has anyone ever used these people before, all the part numbers start with GM could they possibly be original units or equivalent, I personally think equivalent and at those prices.
I was thinking perhaps get one as a temp fix as the MOT is coming up then change afterwards when I am abit more flush.
Would this site be a good one to use, has anyone had any dealings with them before.
Just emailed there sales department so shall see what they have to say.
R-PAC
#16
we had a leak on our V6 that we could not find anywhere (was losing about half inch a week)
took it to local independent vauxhall garage, they did pressure test and found the leak was inside the v, said it was a small washer and was not worth a strip down to do it due to cost.
they dropped a "resin s**t stick" (there words not mine) in the water bottle and the leak stopped withing days and we have had no problem with it in the past 2 months.
they told us that the resin stick is a genuine vauxhall part complete with vauxhall parts number.
Jeff
R-PAC
forgot the best bit,
the test and resin stick only cost £5 donation to the tea fund
nixoro
Cheers R-PAC
I cant say I have heard of a resin stick trouble is its definately the rad trickling so I know whats causing it question is would the stick do the job on the crack.
R-PAC
i had not heard of it either before this, if you can get hold of one its cheap enough to give a try, could buy you time to shop round for a new rad
nixoro
I might just call into Vx on the way home, has anyone got a way of finding out the proper part number for this stick.
Cheers
Roy
nixoro
QuoteI know I have said Gen Vx would be the way to go but I have just been searching online and found a website that does Radiators for my Omega for £93.03 ideally I need to get it done ASAP
In response to this earlier post i have just received an email stating they supply O.E standard equipment and would be able to do next day delivery, not sure whether this is a good deal or not all in with delivery + Vat I have been told it works out at £121.06, still following up a few other sources but may come back to this one.
nixoro
Can anyone confirm for me whether the AC will be effected when I remove my Radiator only sods law I have only just had it regassed and the last thing I need is to get it re done.
Everywhere I have gone for quotes etc, I have been asked whether it has AC manual/auto, surely there wouldn't be a big difference.
M-Tek Performance
Automatic radiator is different to the manual - it has extra pipes going to it.
the reason for asking about air con i would guess is possibly for mounting points??
0845 46 REMAP
(0845 46 73627)
www.mtek-performance.co.uk
www.chipmycar.co.uk
nixoro
#24
QuoteAutomatic radiator is different to the manual - it has extra pipes going to it.
Cheers M-Tek Performance
Makes sense when you say about the mounting points  :)
hotel21
You can change the engine radiator without disturbing the AC system.
I got a brand new in box genuine GM radiator off e-bay last year for £55 delivered.  Lucky me!!  It was for an auto (while mine is manual) and all I needed to do was leave the bungs in the holes for the auto fluid pipes.  Engine runs a tad warm (95 - 100) but nothing the fans cant cope with.  Not sure if this is to do with the rad or not.  Suspect not.
HtH
Broocie
Liam
Not too far from you - maybe try Kempston Radiators in, well, Kempston.  I've used them in the past and they're nice and cheap.  Have you considered asking about getting your existing rad re-cored rather than buying a whole new one - could save a load of squids.
Liam
nixoro
QuoteNot too far from you - maybe try Kempston Radiators in, well, Kempston.  I've used them in the past and they're nice and cheap.  Have you considered asking about getting your existing rad re-cored rather than buying a whole new one - could save a load of squids.
Liam
Liam I cant say I have heard of kempston radiators before may give them ago, when you say get my current one re-cored will it have a new plastic cover fitted only the crack is at the top of the plastic section, well not so bothered about the cover just need to get the leak gone now.
nixoro
QuoteYou can change the engine radiator without disturbing the AC system.
HtH
Broocie
Broocie
I have to say for £55 thats jammy, wish my luck was as good as yours, I have spoken to someone with regards an auto rad but if I can get a manual rad I would feel alot happier.
mr des
have you looked at ont for a 2l vectra as im pretty sure mine has a 2nd veccy one in it when i bought it
i want to shine in the eye of orion but i drove my sole through the black hole
