Author Topic: Testing rear multi-ram  (Read 2550 times)
Paul M
  • Edinburgh
« on: 27 August 2006, 16:13:22 »
Mark thinks my rear multiram isn't working properly as I describe the car as being gutless below 4500 RPM. I'm not sure, because I'm comparing with a 4.4 V8 in my BMW that pulls well from 800 RPM! However I'd still expect the Omega to be better than it is, being a 3.0. My dad's 330Ci feels loads better in normal town driving - not sure whether this is a VANOS engine.
So how do I test it? Seem to remember some thing where you start the engine, open the bonnet and quickly open the throttle while watching the front & rear flaps move under different conditions of throttle + RPM.
Re: Testing rear multi-ram
« Reply #1 on: 27 August 2006, 20:35:39 »
They ar eboth under ecu control. So assuming ecu isn't buggered (or its wiring, but that would bring on EML), test the vacuum and actuator.
Firstly, move actuator by hand - should more easily, and full stroke is about 1"
Secondly, unplug the vacuum hose on vacuum side of solenoid (bit the electrical connector plugs in) - should get a good hiss as vacuum sucks in last for about 1s.
Suck on the vacuum hose goingto actuator the other side of solenoid (short U shaped bit of hose) - actuator should move full stroke.
RonaldMcBurger
« Reply #2 on: 27 August 2006, 21:45:28 »
If the throttle is cable operated (as oposed to fly by wire) look at the multiram as you blip the throttle full open. It should move.
« Reply #3 on: 27 August 2006, 22:15:38 »
Or plug in Tech2 and use the 'Actuate multiram valves' feature....
Paul M
  • Edinburgh
« Reply #4 on: 28 August 2006, 12:32:49 »
OK cheers guys, I'll give it a go when the rain goes off!
