Pages: [1] 2 3  All   Go Down
Author Topic: Knock Sensor 2  (Read 10902 times)
Knock Sensor 2
« on: 28 August 2006, 19:03:55 »
Project TB1 keeps lighting up EML with Knock Sensor Circuit 2.
I think I need to renew the plenum O rings as they look tired, and there does seem to be a sucking noise from under plenum.
Could this possible air leak cause the knock sensor error? Or should I be replacing knock sensor? Can they be swapped side to side (see if fault moves with sensor or stays on same bank)?
Any pointers on what else can cause this problem would be appreciated....
I also reckon the car is holding back a little, esp under load...  ...related? Could be, as normally when eml comes on...
Taxi_Driver
Re: Knock Sensor 2
« Reply #1 on: 28 August 2006, 19:35:07 »
Is the part number the same for the two?? Different part numbers would suggest a difference.
Did you change the petrol filter?
Cheers
Re: Knock Sensor 2
« Reply #2 on: 28 August 2006, 19:37:00 »
I haven't changed fuel filter - wouldn't have thought that would cause knock sensor probs? Might affect performance though...
Re: Knock Sensor 2
« Reply #3 on: 28 August 2006, 19:41:52 »
Struggling to find Knock sensor part codes, probably Vx call them something else...
Taxi_Driver
Re: Knock Sensor 2
« Reply #4 on: 28 August 2006, 19:42:51 »
Soz didnt really make myself clear....
I was on about fuel filter for the 'holding back' prob
Re: Knock Sensor 2
« Reply #5 on: 28 August 2006, 19:44:06 »
Found the part nos, look like same each side. Just need to find them on the car.....
Re: Knock Sensor 2
« Reply #6 on: 28 August 2006, 19:46:10 »
I think the holding back may be related to knock sensor (this would retard ignition I guess?).... ...I'd be surprised if the fuel filter would make that much difference (this car does seem quite sluggish).
STMO123
Re: Knock Sensor 2
« Reply #7 on: 28 August 2006, 19:51:55 »
Knock sensor locations are in section 4A/7 of the haynes, Jaime
Re: Knock Sensor 2
« Reply #8 on: 28 August 2006, 19:54:24 »
Cheers! Didn't think of refering to book of lies  :-[
Mind you, Haynes has realling pissed me off today. The wiring diagrams are not matching my car  >:(
Re: Knock Sensor 2
« Reply #9 on: 28 August 2006, 19:58:15 »
Thats not Haynes fault, its your car not matching the diagrams... ;) ;D
Taxi_Driver
Re: Knock Sensor 2
« Reply #10 on: 28 August 2006, 20:03:35 »
Your prob rite m8.....just remember Ron saying changing the fuel filter on one of his many, made a world of difference   :)
Re: Knock Sensor 2
« Reply #11 on: 28 August 2006, 20:05:50 »
My MV6 one was fairly dirty (thanks dealer, for charging me for replacing, and not  >:(), but difference wasn't really noticable.
Taxi_Driver
Re: Knock Sensor 2
« Reply #12 on: 28 August 2006, 20:05:50 »
Thats good.....must be the same then  ;)
But dont ask me where they are......you've got more stars than me....so you should know  :D
JasonH
Re: Knock Sensor 2
« Reply #13 on: 28 August 2006, 20:22:03 »
I believe the knock sensors are piezo ceramic, so they're likely to give a problem if cracked (physically damaged) or loose. Otherwise there's not much else to go wrong except wiring.
I'd check it's on tight first.
I wouldn't expect an air leak to fool them.
Re: Knock Sensor 2
« Reply #14 on: 28 August 2006, 21:32:43 »
Read the Haynes, look like a right PITA to get to...  >:(
Pages: [1] 2 3  All   Go Up
Page created in 0.023 seconds with 20 queries.
