Author Topic: Need help with my Big End!  (Read 9304 times)
cipher
  • Derby
Re: Need help with my Big End!
« Reply #15 on: 16 August 2006, 17:29:54 »
sounds like I got me an excuse to fit some 3.0 cams!  ;D
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
cipher
  • Derby
« Reply #16 on: 16 August 2006, 17:33:48 »
Just thinking about it, this knocking sound came on very suddenly.
There was no build up to a knocking noise, its not getting any louder, its has been like this now for about 3 weeks. So, that doesn't sound like bottom-end to me, just this was my fear.
And it has had some good pastings in that time.
« Last Edit: 16 August 2006, 17:34:40 by cipher »
PM For Details
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #17 on: 16 August 2006, 20:22:16 »
Er........ the splash plate is in the way matey!!!!!! or it was when we built it!!!!!
The only way you can do this with the engine in the car on an Omega is by dropping the subframe but you will need to support the engine somehow - using an engine bridge.
If you drop the small sump the big end on the conrods are quite easliy accessable.
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #18 on: 16 August 2006, 20:24:31 »
I would be very willing to help out mate - but I'm off to Portsmouth in a couple of weeks then Afgahnistan  not that near to Derby.
Should have internet though so can help via here
is that an offer of help there Geff?
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #19 on: 16 August 2006, 20:26:53 »
If it came on suddenly then check your oil pressure - should be 1.8 bar @ idle and 5 bar max - you check it from the oil pressure switch - if you are stuck for a gauge I could post mine to you - you pay postage of course
Theres a relief valve and an oil pressure regulator valve in the oil pump - these (with a huge bar) can be removed / replaced - but you need to check pressure first
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #20 on: 16 August 2006, 20:33:17 »
they were but we were allowed to interchange one bearing cap per cam in the factory
yes that was quite worrying, guess that being loose has mullered the bearing?
So if the bearing is mullered could it be changed from another car, only heard  rumour they are built specific for each Head etc, any truth.
cipher
  • Derby
« Reply #21 on: 08 September 2006, 00:04:57 »
Sorry to drag this one back up, but this obviously isn't going away on its own, and I'm not going to do the womanly thing of turnign the radio up to hide the noise.
I want to get this resolved before it gets serious.
Geff, what gauge/connector/fitting would I need, would a local garage have this tool? just thinking maybe I can slip them beer tokens....
If not, then how much you reckon for postage?
If the cam(s) are walking, what is likley to be damaged, and what is simplist (and cheapest) way of fixing this?
Is there a check I can do see if the noise is top or bottom end/ Dont want to spend money sorting the cams if this isnt the problem. Roughly how much am I looking for it if its the bottom end?
Sorry lots of questions, have had no time recently to look at it or even think about it.
Thanks.
PM For Details
