Author Topic: Stalling omega  (Read 3244 times)
sujole
  • Hemel Hempstead
Stalling omega
« on: 07 September 2006, 20:46:42 »
Hi
I have just bought a 99 'S' plate 2.5 CD. It has a large amount of history which has included rocker cover gaskets, Idle control, crank sensor, dis pack, leads and cats.
I love the car but it has a minor problem - it cuts out.
Some mornings it is hard to start and others it fires first time. Some days it will run perfectly, others it will cut out.
The cutting out gives no warning, the engine just stops. No warning lights before the event and it will start immediately after.
Any ideas gratefully received.
John
Re: Stalling omega
« Reply #1 on: 07 September 2006, 20:51:24 »
Does it cut out only on idle or when cruising also.
sujole
  • Hemel Hempstead
Re: Stalling omega
« Reply #2 on: 07 September 2006, 20:53:54 »
It runs perfectly until I stop and let it idle. There is no hesitation when accelerating and the car appears to have plenty of 'oomph'
Re: Stalling omega
« Reply #3 on: 07 September 2006, 22:06:58 »
Idle Control Valve is still favourite, but air intake leaks and EGR problem are also possibilities...
Matchless
  • Nottingham
    • A white van
Re: Stalling omega
« Reply #4 on: 08 September 2006, 11:16:11 »
It could be idle control valve sticking but the other possibility is the crankshaft sensor.
The sensor output voltage increases with speed, if the sensor or cable is failing then there may be sufficient signal at normal rpms but not at idle or when cranking, hence poor starting and cutting out.
JasonH
  • Online Online
Re: Stalling omega
« Reply #5 on: 08 September 2006, 23:56:50 »
When you say hard to start, does it turn over healthily but just not fire at all ?
If so I'd suspect the cranksensor.
sujole
  • Hemel Hempstead
Re: Stalling omega
« Reply #6 on: 09 September 2006, 19:02:17 »
It turns over perfectly. It will take a couple of times before starting and other times it will start first time.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Stalling omega
« Reply #7 on: 09 September 2006, 19:06:52 »
I had a similar sort of problem with my 2.2 which turned out to be the cam sensor.
I like red cars
Allenm
  • Milton Keynes
Re: Stalling omega
« Reply #8 on: 09 September 2006, 19:45:56 »
Sounds very much like crank sensor to me
JasonH
  • Online Online
Re: Stalling omega
« Reply #9 on: 10 September 2006, 15:27:23 »
I'd say crank sensor.
£50 for a sensor. A bit of fiddling about to fit it and the problem will disappear.
