Author Topic: Mini Facelift- how do you tell & what was improved  (Read 9164 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Mini Facelift- how do you tell & what was impr
« Reply #15 on: 15 September 2006, 23:25:24 »
Makes no sense at all....I have the solid headrests, repositioned TC button, but no side airbags!!! [smiley=shocked.gif]
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #16 on: 15 September 2006, 23:33:00 »
Looks like the reflection was a real mix of parts mate, mines the same.
TuBy's new whipping boy.
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #17 on: 16 September 2006, 00:25:00 »
Thanks for all your replies!
It looks like I have a mini facelift then :)
My TC buttin is the older style one BUT I purchased a load of switches from e-bay as some of the legends on mine had worn so I swapped them out (the "soft feel" switches are very bad for this apparently).  In the batch of switches I have a new style TC switch so I will investigate swapping them round.  I prefer the look of the TC switch being in the same bank.
By the way, ignore what the Haynes manual says about removing the switches.  I found it best to remove the heater / climate panel and press on the top clip thereby releasing the switch.  As one of my "new" switches does not light up >:( I will be doing this again in a while and will do a how to at the same time.
If I swap the TC switch, I will do a how to on this as well.
