Author Topic: engine electronics fault light  (Read 10339 times)
Re: engine electronics fault light
« Reply #15 on: 17 September 2006, 10:19:40 »
I don't know, but I would have thought the 8v would still use a similar loom and setup?
johnny.dee
  • essex
« Reply #16 on: 17 September 2006, 11:27:19 »
I have now found the diagnosis socket and it is indeed in the fuse box. (definately in the engine compartment for the carlton)
The fault code is 69 which according to the chart in front of me is the air flow temperature unit reading low volts. Have checked and rechecked the connections but cannot see how I could have caused the fault light to appear. My next thought is on removing the air flow pipe I must have buggered up the sensor, but I cant see how as it was enclosed in the pipework.
« Reply #17 on: 17 September 2006, 13:25:17 »
Have you put the air temp sensor connector onto the front multiram connetor and vice versa (both are two pin plugs)
johnny.dee
  • essex
« Reply #18 on: 17 September 2006, 14:14:08 »
Oh dear I am a silly billy,run the cables a different way to original and ended up with the connectors wrong, all ok now.
once again you have saved my bacon Mark BIG THANKS.
« Reply #19 on: 17 September 2006, 19:29:24 »
Lol....your not the first to do it so dont worry about it.
Well done on the cambelt change!
