Author Topic: seat removal front  (Read 3320 times)
marcbcfc
  • dorset
seat removal front
« on: 17 September 2006, 12:37:12 »
Hi
can anyone tell me what size torx fitting is required to remove the front seats as they seem to be well tight and ive snapped one already
thanks marc :-[
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
Re: seat removal front
« Reply #1 on: 17 September 2006, 16:17:31 »
Woo hoo! my first post giving some help rather than always receiving it  ;D
I just checked my facelift Marc and it is a T40 torx bit that fits the seat runner to floor bolts. Hope this helps, Cheers jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
« Reply #2 on: 17 September 2006, 19:28:19 »
Yep T40....what year is it as you either need to disconnect the battery or fit some locking bits to stop the pre-tensioners going off.
« Reply #3 on: 17 September 2006, 19:48:29 »
... and a bowl or two of  Shredded Wheat! They're heavy!
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« Reply #4 on: 17 September 2006, 20:03:24 »
I'm changing my interior this week, didn't know about the pre-tensioner, thanks for that could have been a little accident :)
« Last Edit: 17 September 2006, 20:04:37 by jim »
STMO123
« Reply #5 on: 17 September 2006, 20:36:35 »
............in my pants if they'd gone off unexpectedly ;D
marcbcfc
  • dorset
« Reply #6 on: 17 September 2006, 22:05:32 »
its a 1996 pre-facelift i won some leather ones off e-bay and managed to strip everything out apart from the front seats as they seem to be well solid i realised about the pre-tensioners luckily mine have still got the licking clips if anyone needs any tips on taking the door cards out let me know as i spent most of saturday striping the inside out ---apart from the friggin front seats any thanks for the info guys il let you know when ive taken them out and fitted the leather with pics
marc :o
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 17 September 2006, 22:11:55 »
I saw some seat bolts at Marks today, they are quite long and originally had 'dry' loctite applied to them. This can be a sod to get moving, sometimes helps to tighten the bolts fractionally before undoing.
Can you get to the underside of the bolts? (I have no idea where they go) if you can, and its somewhere you can heat with a blowlamp then heat softens this type of loctite.
marcbcfc
  • dorset
« Reply #8 on: 17 September 2006, 22:18:20 »
No there is not much room for working in but ive got a little blow lamp i might just give it a burn but unfortunately the torx bit i was using sheared off in one bolt so--ive got to drill the bugger out but thats another job for the weekend
thnks for the replys guys :-X
Matchless
  • Nottingham
    • A white van
« Reply #9 on: 17 September 2006, 22:44:49 »
Is the end of the torx bit stuck in the bolt?
If so use a centre punch or similar to try to rotate the broken bit clockwise (tightening direction) with any luck it will lose its grip on the bolt and a magnet should lift out the broken bit.
I have found that the cheap torx sets are just that...cheap. The ones sold by Machine Mart seem better quality as are the Halfords Professional, go for ones that have integral 3/8 or 1/2 adaptors rather than the one_adaptor_lots_of_bits sets.
Its nearly Christmas, add a quality set to the list.
