Author Topic: heating and ventilation  (Read 3935 times)
johnny.dee
  • essex
« on: 22 September 2006, 21:07:34 »
Now the cool evenings are drawing in, I thought I might try correct a little fault with my heating and vent system.
The heating and cooling work fine, the problem is I cant seem to get it directed into the footwells no matter what what I set both dials to.
Haynes seem to say I have to have the centre console apart, (which is the reason I havent bothered before) and it is vacuam controlled. Any ideas lads?
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: heating and ventilation
« Reply #1 on: 22 September 2006, 21:09:40 »
More than likely one of the vacuum pipes in the engine bay
« Reply #2 on: 22 September 2006, 21:19:44 »
Vac feed pipe to the heater system from the engine bay is ok is it......can you hear a hiss at all when you turn the direction dial.
Got the cam locking kit back by the way...thanks!
johnny.dee
  • essex
« Reply #3 on: 22 September 2006, 22:05:15 »
checked all the vac pipes and heater pipes when I changed the oil cooler a couple of weeks ago, all ok.
No hiss has been heard.
Timbuk
  • Telford
« Reply #4 on: 22 September 2006, 22:17:42 »
Where it passes through bulkhead ok?
johnny.dee
  • essex
« Reply #5 on: 23 September 2006, 13:37:08 »
yes all ok. I am still able to divert the air flow from screen to mid level vents,
Haynes say I have to remove the aircon gas before removing the control panel for a look at the vac pipes there, is this correct?
« Last Edit: 23 September 2006, 13:39:04 by johnny.dee »
« Reply #6 on: 23 September 2006, 19:05:44 »
No its not correct....you can simply pop the panel out .....and then there is a rubber assembly with the vac pipes in it on the back of the direction switch.
