Author Topic: Changing Fuel Filter (v. basic)  (Read 5624 times)
Sir_Mixalot
« on: 31 August 2006, 17:19:30 »
Firstly, apologies if this has already been covered, i did a search and checked the faq and maintainace sections to no avail.
Basically how do you get the fuel filter off the car?!  I sat under the car for a good 45 minutes fiddling with pliers and knives trying to get the fuel lines off it without damaging them but had no luck.  The Haynes is very breif with something like "unclip the fuel lines"...but i can't for the life off me see how todo it - well i can see how todo it (push in both clips and pull appart!); but i can't manage todo this.  Is there a special tool or way to modify an existing tool todo it?
As a sub question, i am doing a service on the car, changing:
oil + filter, air filter, pollen filter, fuel filter, spark plugs and coolant
...anything else I should do?
Thanks alot.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Changing Fuel Filter (v. basic)
« Reply #1 on: 31 August 2006, 17:33:09 »
I like red cars
Sir_Mixalot
« Reply #2 on: 31 August 2006, 17:36:02 »
cheers for looking but - £13!!!
Now way todo it without these?
« Last Edit: 31 August 2006, 17:36:36 by Sir_Mixalot »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 31 August 2006, 17:42:01 »
You could search on e-bay, but look at it htis way, how much would it cost at a garage to have the fuel filter changed?
« Last Edit: 31 August 2006, 17:42:20 by Auto_Addict »
I like red cars
nixoro
  • Hitchin, Herts
« Reply #4 on: 31 August 2006, 17:44:16 »
And also you will have the correct tool for the next time it needs replacing. I just used a set of adjustable pliers myself.
« Last Edit: 31 August 2006, 17:46:37 by nixoro »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #5 on: 31 August 2006, 18:44:34 »
[I just used a set of adjustable pliers myself.
But you're an Omega expert........ ;)
I like red cars
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 31 August 2006, 19:43:15 »
I haven't done this yet, but hope to soon. I remember reading though that you have to de-pressurise the fuel line first! Has this been done?
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #7 on: 31 August 2006, 20:11:15 »
I've used the correct tool  - still a bit iffy with that.
Also did one with a pair of wire strippers - the one with a v notch - then put the filter on back to
front - duh!
When I bought the filter I bought two new clips as well
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Bo Bo
  • Coventry
« Reply #8 on: 31 August 2006, 20:24:09 »
front - duh!
Just bought one & mine came with the clips, will be trying this soon.
« Reply #9 on: 31 August 2006, 21:06:34 »
I did with a pair of long nose pliers and a screwdriver. Have you got the replacement clips as well as filter so you can see exactly what you need to do (basically squeeze the retaining tabs)?
dellboy
  • borehamwood herts
« Reply #10 on: 31 August 2006, 21:49:35 »
i did mine 2 weeks ago with wire strippers took about 10 min without breaking clips
Markjay
  • London
« Reply #11 on: 26 September 2006, 23:07:53 »
I think you may need these...
http://www.machinemart.co.uk/product.asp?p=040211441&r=2076&g=111
Stop improvising, as AA says get the job done using proper tools...  ;D
« Last Edit: 26 September 2006, 23:09:11 by markjay »
Alas, no more Omegas....
Admin
« Reply #12 on: 27 September 2006, 07:18:34 »
Thread tidied to remove off topic posts!  ;)
The Administrator.
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #13 on: 27 September 2006, 08:16:38 »
Naughty.  ;D
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Ghosts in my machine
  • Derby
« Reply #14 on: 27 September 2006, 11:49:25 »
Being a tight fisted Yorkshireman, I had the same reaction to the price of the special tool for fuel filters so decided to try without. Especially as I'd got the filter for a dirt cheap price, and didn't want to waste my saving.
A Bit fiddly, but with rear wheel removed (presume yours is in same location) and using a small terminal screwdriver, they came off a treat. Just push screwdriver in and partially unclip one side, keep some pressure on to pull apart, then do other side the same. after a couple of tweaks like this, it came apart.
I did think that my circlip pliers with the 90 deg angle end on would do it, but couldn't find them at the time (found 15 minutes after getting wheel back on! [smiley=rolleyes.gif])
Dyslexic dwarves.... there not big and they're not clever!
Page created in 0.029 seconds with 20 queries.
