Author Topic: Timbuk's non-starter  (Read 6765 times)
theolodian
  • I need a new avatar.
« on: 27 September 2006, 13:23:50 »
Had a quick look this morning.  Cranks and sputters a bit, but doesn't quite catch.  Battery is a bit low, cranking slowly.  Engine light seems to be burnt out, doesn't come on when key is turned on before starting.  Can't hear the fuel pump running, but the fuse is OK.  Tried spraying carb cleaner in intake to see if it would cough, but it didn't.
Any suggestions?  I am off to research the paper clip trick and make sure that it requires a working engine light.
Bo Bo, do u have a charger or jumper cables?
theolodian
Re: Timbuk's non-starter
« Reply #1 on: 27 September 2006, 13:35:50 »
OK, I've gotta get off this PC.  If you have my number or Timbuk's, please text one of us.
Cheers,
Theo
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #2 on: 27 September 2006, 13:37:18 »
If the fuel pump isn't running while it's turning over then it's the crankshaft sensor.  ;) I'd bet my left bollock on it.  ::)
Also, It wouldn't cough no matter what you sprayed in there, cos if it doesn't know what angle the crank is at, it won't generate a spark either.
* EDIT * You'll also need a working EML to paperclip it.  ;)
« Last Edit: 27 September 2006, 16:22:58 by Kev »
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Bo Bo
  • Coventry
« Reply #3 on: 27 September 2006, 14:16:32 »
Cheers,
Theo
OK
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #4 on: 27 September 2006, 15:44:08 »
Hi,
Just a thought - although I agree with the crank sensor and it proabbly is this very thing, have you checked the fuel pump relay?  I would also check the location of all the other relays in the case by the ECU.
However, no doubt it is the crank sensor.
STMO123
« Reply #5 on: 27 September 2006, 16:27:17 »
Right! If its not the crankshaft sensor we'll have to draw lots to see who comes up to Glasgow to do the deed with Kev's left knacker ;D
« Reply #6 on: 27 September 2006, 16:42:26 »
I think I have a set of tin snips somehwere.....
Kev
  • Glasgow
« Reply #7 on: 27 September 2006, 16:46:21 »
 ;D ;D
You know i'm really hoping it's the crankshaft sensor now don't you.  :o
* EDIT * I suppose it'll make a change from the standard cam belt change party, A knacker removal party.   ::)
« Last Edit: 27 September 2006, 17:11:54 by Kev »
theolodian
« Reply #8 on: 27 September 2006, 17:42:48 »
Well, you're in trouble!  :o  It wasn't the crank sensor  :P
The a/c is seized.  Took off the accessory belt and it started.  Can a non-a/c belt be used to bypass the a/c?  I think that I read about that somewhere on here . . .
nixoro
  • Hitchin, Herts
« Reply #9 on: 27 September 2006, 17:46:25 »
Yep from what I have read on here you can put a V6 belt on which is for a v6 without AC to bypass the AC compressor. :)
« Last Edit: 27 September 2006, 17:46:46 by nixoro »
Kev
  • Glasgow
« Reply #10 on: 27 September 2006, 18:14:14 »
Tank filled...I'm offskey.  ::)
« Reply #11 on: 27 September 2006, 18:19:31 »
I reckon you've shit your binfull now...  ...we'll give you a ten minute headstart  ;D
Kev
  • Glasgow
« Reply #12 on: 27 September 2006, 18:22:28 »
Think i'll be able to blend in with the other traffic, i'll never get spotted.  ;)
RonaldMcBurger
« Reply #13 on: 27 September 2006, 18:35:20 »
Changes name by deed poll to: Whodyanickaknackeroff
theolodian
« Reply #14 on: 27 September 2006, 19:15:47 »
Signal to noise ratio is pretty low on this forum.  All the threads seem to go off-topic pretty quickly.  Oh yeah, I'm one of the reasons why  ;)
Do people concur with Nixoro?  If so, then that's what we'll do.  (I don't need a ton of replies, but Nixoro wasn't completely sure.)
Page created in 0.022 seconds with 20 queries.
