Author Topic: Another thing about Timbuk's car . . .  (Read 6413 times)
theolodian
  • I need a new avatar.
« on: 28 September 2006, 11:22:42 »
When we took the belt off it did start, but only with a lot of blipping the throttle.  Idle is not very smooth either.  The really strange thing was a noise from the plenum like the hollow hiss you get when filling up an air tank.  If you pinched off the hose to the idle valve then the noise went away, but the car didn't run any differently.  The throttle bodies have a thick layer of sludge on the bottom.  We're going to clean them, but is there anything else we should look at?
Matchless
  • Nottingham
    • A white van
Re: Another thing about Timbuk's car . . .
« Reply #1 on: 28 September 2006, 11:29:42 »
Sounds like an air leak, if you pinch off the idle valve air supply you would expect it to stall or surge when you released it again.
« Reply #2 on: 28 September 2006, 11:49:24 »
Once the throttles have been cleaned, check that the stop adjust results in them being fully closed, I have seen two now where the throttle stop has been in-correctly adjusted to stop engine stall.
theolodian
« Reply #3 on: 28 September 2006, 11:58:06 »
OK, cheers!  Wouldn't have known.  We'll try to clean the idle valve too, make sure that isn't stuck wide open.
Admin
« Reply #4 on: 28 September 2006, 13:38:29 »
This is a time when you need to clean the entire breather system (reference Mr Mcb's guide).
Everything will clean up well, (remember you should be able to blow through the breather pipes) just take your time and use plenty of carb cleaner/paraffin.
We came across a similar thing with James V6CDX's car.
Thoroughly cleaning the whole system resulted in smoother running, better throttle response and noticably improved MPG! :)
On a side issue. I have deleted posts on here as they were off topic.
Please can we keep the help threads on topic?
Thanks
Dave. :)
The Administrator.
Bo Bo
  • Coventry
« Reply #5 on: 28 September 2006, 17:16:09 »
Timbuk popped round earlier, he's putting the new belt on this evening & we'll clean the breathers when we do our cambelts on Sat, so won't know til then.
« Reply #6 on: 28 September 2006, 17:21:50 »
Can someone PM me an address for Sat, along with a time?
« Reply #7 on: 28 September 2006, 17:22:21 »
Also, how many cambelts are we doing?
Bo Bo
  • Coventry
« Reply #8 on: 28 September 2006, 17:37:09 »
PM you in a mo.
theolodian
« Reply #9 on: 28 September 2006, 19:06:55 »
Does that mean that people want plenum o-rings?
TB, 2 cambelts and my cam covers, although with the rain prediction my cam covers look iffy.
Bo Bo
  • Coventry
« Reply #10 on: 28 September 2006, 19:23:50 »
If they're gonna need replacing, then I guess I'm gonna need some  ;)
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #11 on: 28 September 2006, 20:53:39 »
That'll be...
2 Cam belts.
1 Cam Cover gasket set.
1 Crankshaft Sensor.  ;)
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #12 on: 28 September 2006, 21:26:05 »
She's running, was quite difficult to source the V6 belt as marks DTM said it might be. A trip round to Bo Bo's and 4 belts later but i got one, popped it on tonight and off she went. replaced some bulbs so i could do a paperclip test while i was at it. Results as follows. (if i understood correctly)    144,135 and 31 ? Main thing is were running again so i can still take part in the beer festival at the weekend... er, sorry, cambelt party ;)
« Reply #13 on: 28 September 2006, 21:32:09 »
Too tired to look up codes (I'm sure someone else will), but expect a 31 if engine not running, 144 is immobiliser iirc, can't remember the 135 one...
Timbuk
  • Telford
« Reply #14 on: 28 September 2006, 21:39:21 »
Main thing is she's running, can sort the fault codes at a later date ;)
