Author Topic: Should I buy a Tech2 or OBD CAN scanner?  (Read 1673 times)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« on: 28 September 2006, 22:41:17 »
I'm thinking of buying a Tech2 interface with R232 cable & software for £45 - does anyone know if I can get one cheaper.  Alternative is a OBD CAN code reader/reset for about £30 but not sure if codes will mean much to you guys when faults appear.  Any thoughts?? ::)
Markjay
  • London
Re: Should I buy a Tech2 or OBD CAN scanner?
« Reply #1 on: 29 September 2006, 00:16:38 »
'Tech2' has flakey software (part of it is in Hungarian), but sort of works. You'll need a laptop with proper serial port, not rs232/USB convertor. Don't think you'll get it for less then £45, seems to be the going price for it.
As for CAN BUS, post the link (eBay?) to the exact item, maybe someone else will be able to help.
Alas, no more Omegas....
