Author Topic: Cambelt change  (Read 2603 times)
Cambelt change
« on: 30 September 2006, 19:46:09 »
Am I right in thinking that on the 2.0 Engine, no special timing tools, apart from the little one to lock the cams together, are needed to do a cambelt change?
Eg - just refit the belt onto the locked cams, and then set the tensioner as usual?
I guess the tensioner marks go in the same place as on a V6 change with a new belt - eg take the tensioner approx 4mm past the mark?
Re: Cambelt change
« Reply #1 on: 30 September 2006, 20:24:49 »
Thats correct...the tensioner has markings for new and used belts to.
Re: Cambelt change
« Reply #2 on: 30 September 2006, 20:31:32 »
Cheers Mark you're a star
Matchless
  • Nottingham
    • A white van
Re: Cambelt change
« Reply #3 on: 30 September 2006, 22:18:55 »
Please say that you are changing the water pump at the same time.
Re: Cambelt change
« Reply #4 on: 30 September 2006, 22:20:33 »
Of course!
Pointless fitting a new cambelt kit, if it's going to be ruined by the water pump falling to bits :D
Kev
  • Glasgow
  • .:The OmegaProject:.
Re: Cambelt change
« Reply #5 on: 30 September 2006, 23:04:17 »
Yep, it'll be a brand new water pump, but the cambelt is part worn.  ;D
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
