Author Topic: Flat battery  (Read 6784 times)
Flat battery
« on: 05 September 2006, 20:23:17 »
My wife has been using the Omega this week and has been complaining that it turns over slowly which I thought was rubbish as it was ok last week. She took her own car this morning so I went to B&Q in the Omega guess what very slow to turn over. I think the battery is on its way out as after a 15 minute run the car starts OK but if I go back to it a couple of hours later its slow again. The charge light on the dash goes out as normal so any suggestions.
Re: Flat battery
« Reply #1 on: 05 September 2006, 20:30:21 »
As you say, tired battery. But test it first.
Give us readings of when engine not running, engine at 2.5k, engine at 5k (should be around 12.5,14.2,14.2 approx)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Flat battery
« Reply #2 on: 05 September 2006, 20:31:24 »
Mine started to do that, would be ok during the week but would need a boost to start on Monday morning.
End result too much using the booster killed the battery and the replacement cured the trouble totally.
TuBy's new whipping boy.
Taxi_Driver
Re: Flat battery
« Reply #3 on: 06 September 2006, 06:36:28 »
Not sure how much discount you get at vx dealer with TC card for batteries
But you get 50% off with Halfrauds trade card for batteries
If you havent got either, it'll be worth trying to find someone close to you that does  ;)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Flat battery
« Reply #4 on: 06 September 2006, 15:33:17 »
I regulary check the voltage of my battery, especially so now the nights are getting darker and more load is put onto the battery.
If mine drops below 13.5v, I put it on a trickle charger immediately.
I like red cars
STMO123
Re: Flat battery
« Reply #5 on: 06 September 2006, 19:03:06 »
As has been said in previous threads, modern batteries just seem to give up the ghost almost without warning sometimes.
Taxi_Driver
Re: Flat battery
« Reply #6 on: 06 September 2006, 19:25:41 »
Isnt that a bit of a pain tho AA, assuming you disconnect the -ve from the battery first,
having to reset windows/radio code etc  :-/
JasonH
Re: Flat battery
« Reply #7 on: 07 September 2006, 20:12:39 »
A nice new battery on TC is only about £33 + VAT.
For the cost of half a tank of petrol it's probably worth getting a new battery - it's only going to get worse as winter approaches.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #8 on: 07 September 2006, 20:28:54 »
I have it on good authority, i.e. from the experts, that if you only trickle charge the battery, you don't need to disconnect it.
I find that during the winter months, especially if you only do short journeys, the battery is hardly ever fully charged, and that's when you get deteriation.
I much prefered my Sennie and my Carlton, they were both fitted with voltmeters, and you could see at a glance the state of your battery.
I like red cars
Re: Flat battery
« Reply #9 on: 07 September 2006, 20:41:50 »
Just to say guys i was reading up in a mag on motors and it said it takes 20 mins driving to put the charge in your battery that it took away from starting the car
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #10 on: 07 September 2006, 21:29:10 »
...and if your running with air con, heated rear screen, wipers and headlights, it's probably just holding it's own...put the heated seats on as well, and your probably running at a discharge....
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #11 on: 07 September 2006, 21:32:26 »
..and to add, if your sat in a traffic jam with all that lot on, your probably discharging at about 30 amps...
I like red cars
Re: Flat battery
« Reply #12 on: 07 September 2006, 21:37:27 »
Im going to Hafrauds tomorrow I might as well get oil,air and fuel filters for all three cars and oil as the trade card only lasts for 3 months
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #13 on: 07 September 2006, 21:48:03 »
It's being reviewed towards the end of October, I understand that the people who have used it the most, and that means using it on non-trade items as well, stand a better chance of keeping it.
I like red cars
Re: Flat battery
« Reply #14 on: 08 September 2006, 07:14:34 »
.........put the heated seats on as well, and your probably running at a discharge....
Which is exactly what the wife & kids do when they get into my cat through the winter. If there was an ammeter the needle would be bent against the 'discharge' stop!
