Author Topic: Plenum removal  (Read 8003 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Plenum removal
« on: 26 September 2006, 16:28:55 »
I know this is really bread and butter stuff for some, but I can't get the removal of the plenum right in my head (tho I am a bit nuts!  [smiley=tongue.gif])
Anyone fancy doing a quick 'how to'? There are some good guides here which start with the plenum removal but they seem to differ slightly. I'm intending to clean my breathers, and maybe at some point do the cam covers.
My motor is pre-facelift, V6.
Cheers
Kev
  • Glasgow
  • .:The OmegaProject:.
Re: Plenum removal
« Reply #1 on: 26 September 2006, 16:33:30 »
You really can't go wrong using Marks excellent Cam cover How2 which you'll find here.  [smiley=thumbsup.gif]
« Last Edit: 26 September 2006, 16:33:49 by Kev »
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Plenum removal
« Reply #2 on: 26 September 2006, 16:35:00 »
Beat me to it Kev  ;D
TuBy's new whipping boy.
Kev
  • Glasgow
Re: Plenum removal
« Reply #3 on: 26 September 2006, 17:02:46 »
Re: Plenum removal
« Reply #4 on: 26 September 2006, 18:22:14 »
Agreed, the cam cover guide covers plenum removal well. Some plenums look a little different due to be larger, but same applies.  2.6 and 3.2 cars have no egr or throttle cable...
If you still need extra info, post back with engine type, and if extended plenum...
RonaldMcBurger
Re: Plenum removal
« Reply #5 on: 26 September 2006, 19:38:47 »
Plenum removal:
You will firstly need to remove the bagpipes - the two black plastic inlet pipes at the front. These are done by loosening the jubille type clips top and bottom, plus the one on the side of the right inlet that joins the smaller rubber pipe.
Next, undo and remove the two small torx bolts on the passenger side of the top of the pleum. An 8mm spanner works well. this releases the cable tray mountings to the passenger side.
Now undo the rubber pipe that goes to the Idle Control Valve on the side of the plenum. Just undo the big jubille clip and slide the pipe off. Then unplug the electrical connector to the ICV.
Then undo the 19mm nut that secures the Servo pipe to the passenger side. Sometimes the servo pipe is fastened to the drivers side rear corner of the plenum with a plastic clip as well.
Next, the two small water tubes to the throttle housing. One each side. just sqeeze the clip with pliers and slide tubes off. Keep them both above the header tank heigfht if possibe, or plug the end with a suitable bolt. (otherwise they just get everything wet!)
The 4 rubber breather tubes at the back of the plenum need to be slid off. The two bigger ones usually have clips that need undoing first. Be careful not to drop the clips behind the engine!
Now, unplug the EGR valve. Levae it connected to the plenum and undo the small securing toirx bolt on the mounting plate near the exhasut manifold, also the large brass nut that unions the EGR to the flexi pipe. Use the handle of a mallet to tap the flexipipe free once the nut is completely undone.
Nearly there!!!
If you want to work on the plenum itself, you will want to remove the throttle cable (and cruise cable if fitted), otherwise you will be able to turn the plenum upside down in situ.
So, to remove the throttle cable, firstly you need to see the tiny question mark shaped clip around the ball of the cable end. Slip the circlip shaped end off and turn it, then you can pull the pin length out of the ball itself - if that makes sense. Now, the ball sometimes comes away from the socket easily, but ofetn not and sometimes not a chance! There is a small clip inside the socket cup that resists taking the cable off, just be gentle with it. Once off, you can renmove the circlip that secures the cruise cable and slide that cable off too. Now, back to the throttle cable. Follow it back to the bracket and you will see a big brassy circlip. Pull that off, and slide the cable back to get it pushed mostly through the hole, then you can access the two E10 size mounting torx bolts for the bracket to plenum.
That all done, you are nearly there.
Undo the 4 big torx bolts on the pleum and remove the bolts. Have a roll of kitchen roll handy. CAREFULLY ease the pleum UP about 1/2 inch, then forward about 3 inches and STOP!!!!!
Now you can access the last bits. Unplug the electrical connector on the back passenger side of the plenum, on the multiram. Also CAREFULLY prise the semi circle shaped u-bend rubber from the multiram, being careful NOT to break the connector or anything else by prising agaisnt it.
Now the plenum is free and you can lift it clear.
IMMEDIATELY take 6 sheets of towel and plug the 6 inlet holes to prevent anything getting in there.
Check all 6 black rubber 'O' rings are still on the inlet manifold, otherwise check the bottom of the plenum. If any are missing, find them. Remove the paper towel one by one if needed and look into the inlet manifold with a torch - you can't miss something as big as those 'o' rings!
There you go. Job done and nothing broken. Easy huh? Takes about 5 minutes with practice.
WARNING!!!!!!
Before you do everything up again, remember the plenum is aluminium and will strip threads easily, so go easy on the white knuckle syndrome. use a torque wrench!!!
« Last Edit: 26 September 2006, 19:41:53 by RonaldMcBurger »
JasonH
Re: Plenum removal
« Reply #6 on: 26 September 2006, 19:55:45 »
Nice set of instructions Ronnie.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Plenum removal
« Reply #7 on: 27 September 2006, 10:08:24 »
Thanks guys, much appreciated.  [smiley=thumbsup.gif]
I'll let you know how I get on over the weekend!!??
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Plenum removal
« Reply #8 on: 01 October 2006, 21:28:27 »
I had hoped to be posting about how I got the job done and how easy and satisfying it was. But no. Between mother nature (weather) and SWMBO, I didn't get the breathers done. Yet. Have worked it out in my head tho and am looking forward to giving it a go.
In the meantime, two more quick questions - what is the torque value for replacing the plenum, and is it worth copper greasing any of the fittings, as I'm sure the plenum will have to come off again soon (camcovers)?
Cheers
theolodian
  • I need a new avatar.
Re: Plenum removal
« Reply #9 on: 01 October 2006, 21:52:44 »
I think the plenum is 8Nm, there is a full list in the guides that you should read.  You will want new o-rings for the plenum, one VX part number is a bag of 6.  They will not need to be replaced again when you do cam covers.  Do not use silicone or other goop, nothing needed on bolts either.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Plenum removal
« Reply #10 on: 01 October 2006, 22:14:38 »
Ok pal - thanks for that. I've just found the guide too. My wrench is 28Nm upwards! More tools required me thinks!
Cheers
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: Plenum removal
« Reply #11 on: 02 October 2006, 00:17:32 »
personally I'd have thought you could just do the cover bolts up hand tight - wouldn't have thought 8Nm would be much more than that. But a torque wrench that goes down to that is essential when doing the cam covers ... cost about £50 from Halfrauds for their professional one. I bought a cheaper one from fleabay intially but it had no locking on the torque setting and the Halfrauds one is much better made ...
theolodian
Re: Plenum removal
« Reply #12 on: 02 October 2006, 08:39:19 »
Yeah, the Halfrauds 8Nm-60Nm torque wrench is ideal, if you can stand the 50 quid price.  The 1/4" torque wrenches (4-20Nm) are hard to find.  Regular torque wrenches, even Argos has them for 15 quid, only go down to 28Nm.  The torque settings that you should use to do the cam belt are 8 (long plenum only), 20, 25 (water pump) and 40Nm.  For the cam cover gaskets they are 8 & 20Nm.  I used 28 instead of 25, but you will want to be able to do 20Nm.
The Barge Captain
Re: Plenum removal
« Reply #13 on: 02 October 2006, 15:38:14 »
Got the plenum removal down to 15 mins on the second time, so still room for improvement.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Plenum removal
« Reply #14 on: 02 October 2006, 16:19:03 »
Have to call with local dealer in the morning to order/prepay the plenum O rings. I got the part number for him from the camcover guide otherwise he wouldn't have been able to find the item! Anyway, £10 something plus vat. Sound about right? Will take a couple of days to arrive though.  [smiley=sad.gif]
My meega has the short plenum by the way.
