Author Topic: EM light on and off  (Read 3708 times)
rhydV6
  • Newtown,Powys
EM light on and off
« on: 03 October 2006, 08:43:23 »
Modded my airbox yesterday (drilled) and left the filter out just to see how loud it sounded, headed off up the road, EM light on and off about 6 times in 2 miles.
Tried flashing the codes (Topbuzz way) but to no avail, I'm assuming EM light didnt stay on for 30secs+ for the code to be stored on the ecu.
Any ideas why the EM light is coming on? I'm assuming it's due to the drilled box+no air filter at the time?
Filter is back in place now.
BTW I'm reluctant to drive the car due to the oil cooler problems, so will not be driving it again now.
www.c-vox.com - Wales Regional Coordinator
Admin
Re: EM light on and off
« Reply #1 on: 03 October 2006, 10:58:33 »
When you say to no avail. I take it you can get the eml to flash out the start up code 12?
Oh and there is no way I would drive the car again until the oil cooler is replaced and the coolant system is VERY thoroughly cleaned.
The Administrator.
« Reply #2 on: 03 October 2006, 18:43:16 »
Agreed with LB66, should at least get a 12, and a 31 if engine not running...
Do not start car until that oil cooler fixed, and flushed through a couple of times ;)
rhydV6
  • Newtown,Powys
« Reply #3 on: 03 October 2006, 19:15:24 »
To no avail means I got no codes to flash.
I bridged A & B with a paperclip, jumped in and turned ignition on, EM light stays illuminated.
Started car, EM light goes out, no flashing...
Car won't be getting moved as it's all taken apart now  :P
« Reply #4 on: 03 October 2006, 20:01:01 »
Eh?
Tell me you are no shorting pins under bonnet - that is the cruise loom ;)
Its the 16 pin diag connector under steering wheel ;)
rhydV6
  • Newtown,Powys
« Reply #5 on: 03 October 2006, 21:13:53 »
Eh?
Ahh bugger lol
Cheers mate  8-)
« Reply #6 on: 03 October 2006, 21:30:53 »
lol
Yeah, pins 4 and 6 of 16 pin diag socket in fusebox under steering wheel  ;D
rhydV6
  • Newtown,Powys
« Reply #7 on: 03 October 2006, 22:15:14 »
Right as I look at it which pins do I bridge? Doing it now so quick reply appreciated  :)
Cheers...
« Reply #8 on: 03 October 2006, 22:22:19 »
Pin 1 bottom left, pin 8 top left, short 4 and 6 (or 5 and 6)
rhydV6
  • Newtown,Powys
« Reply #9 on: 03 October 2006, 22:28:12 »
Cheers
Getting codes 12,16 and 31 with ignition on
So 16, Knock Sensor 1
Wiring issue no doubt  ;)
« Last Edit: 03 October 2006, 22:48:52 by rhydV6 »
« Reply #10 on: 04 October 2006, 19:21:57 »
I can't remember which side Knock sensor 1 is, I seem to recall drivers side. Check plug which is on EGR bracket if it is that side.  If knock sensor 1 is passenger side, it will be cable trapped in cam cover...
STMO123
« Reply #11 on: 04 October 2006, 19:26:00 »
Knock sensor 1 is drivers side. Just had mine renewed today (Unusually, I believe, sensor was knackered, wiring was OK)
rhydV6
  • Newtown,Powys
« Reply #12 on: 05 October 2006, 07:28:37 »
Ummm so this pic I got sent is wrong then?
I'm hoping it is wrong and you are right about it being driver's side as I tried getting at the knock sensor on passenger side lastnight, and gave up as it seems as though I'll be having to remove battery/fusebox/everything else to get at it  :'(
Someone please confirm 100% thank you
Rhyd
« Reply #13 on: 05 October 2006, 09:42:24 »
I had a problem with Knock Sensor 2...
http://www.omegaowners.com/forum/YaBB.pl?num=1156788236/0
and that was def passenger side (cable trapped in cam cover - common problem), so knock sensor 1 must be drivers side...
