Author Topic: Cruise Control - stalk removal  (Read 7118 times)
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« on: 03 October 2006, 17:08:54 »
Hi Guys,
            The Omega that donated it's engine to my car is a CDX and I'm going back to the breakers tomorrow to raid the cruise control from it  :) Can I remove the stalk behind the steering wheel without removing the steering wheel first? The Haynes manual mentions that it unclips and slides off but says to remove the wheel first, just wondered if there was a short cut??
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
Taxi_Driver
Re: Cruise Control - stalk removal
« Reply #1 on: 03 October 2006, 17:33:14 »
Yep you can get the stalk off with out removing the steering wheel.
Spin the steering wheel round until you find 2 screws in the plastic cover....take these out and you can get the covers off. Switch just unclips iirc.
Oh and you might have to unscrew the steering wheel adjustment lever, if its got one.
HTH
Cheers
mijfife
« Reply #2 on: 03 October 2006, 17:35:45 »
That's great TD and thanks for the quick reply! Unfortunately, the breakers cut the cruise control cable when they took the engine out but at least I should get the other bits. I'm hoping it's got the self dipping mirror too  :)
Cheers Jim
Taxi_Driver
« Reply #3 on: 03 October 2006, 17:36:39 »
Just noticed yours is a 2.0, so wont be FBW......so you will need to rob some bits from the engine bay as well.....not sure which bits sorry....as mine is FBW so i didnt need them.
Im sure someone else will be able to let you know which bits you need  :)
« Reply #4 on: 03 October 2006, 18:04:47 »
As well as stalk, you need actuator unit, bowden cable with E clip, a 4 pin brake switch and a clutch switch if manual.
mijfife
« Reply #5 on: 03 October 2006, 18:12:36 »
Thanks The Boy, mine is a facelift auto, will I need the brake switch as well? (I'll probably nab it anyway, should fit in the tool box okay  ;D)
Cheers Jim
« Reply #6 on: 03 October 2006, 18:14:15 »
Not sure tbh, I know the Drive-By-Wire ones have the correct brake switch (and clutch switch if manual), but not sure about non drive-by-wire facelifts...
Prefacelifts do need the replacement switches...
mijfife
« Reply #7 on: 03 October 2006, 18:17:13 »
okay, I'll nab it anyway just to be sure  :)
Cheers Jim
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #8 on: 05 October 2006, 10:28:45 »
you will need the control box as well
I will in time have all the cables if that job is no rush you can have them foc....
selling the stalk and acutator on ebay - simply as the prices seem to be wild currently  ::)
« Reply #9 on: 05 October 2006, 11:59:43 »
You wont be able to use a second hand brake switch I suspect as they are a one shot item......can use a small relay instead though.
« Reply #10 on: 05 October 2006, 12:22:43 »
Only around £11 new for brake switch, so probably not worth buggering around with relay etc...  ...I have successfully reused them though, just fiddly to remove.
mijfife
« Reply #11 on: 05 October 2006, 12:39:55 »
The Haynes manual say to remove "depress the switch locking tabs and remove it from the pedal bracket" I had a look last night to see if I needed the other switch (I do  :() and I can only assume that Mr Haynes has eyes on the end of his fingers to be able to see those darned clips and depress them at the same time  ;D
Cheers Jim
« Reply #12 on: 05 October 2006, 12:53:11 »
Cheers Jim
IIRC, you also have to move a rachet thingie in as well so you have the play to be able to pull switch out...
Agemo
  • Cleethorpes
  • Insignia
« Reply #13 on: 05 October 2006, 20:22:25 »
Been racking my brains, can't remember how the stalk comes off, but it is a doddle. Practice on your old one (nothing to lose if you break it) but you won't.
No need to remove wheel. It is easy to see with the cowl off.
« Last Edit: 05 October 2006, 20:23:56 by Agemo »
« Reply #14 on: 05 October 2006, 20:42:12 »
The stalk simply unclips by depressing plastic tab at top and bottom of stalk, and it slides out...
