Author Topic: Rust bubble  (Read 8281 times)
Rust bubble
« on: 02 October 2006, 10:07:05 »
I noticed yesterday while I was cleaning the car that a small rust bubble has just started to appear in the usual Omega place under the outer window rubber on the rear door. Can anyone tell me how to get the rubber (window rubber ;)) off.
Cheers Pete
« Last Edit: 02 October 2006, 10:07:28 by Elite_Pete »
Eliteman Steve
  • Brighton
Re: Rust bubble
« Reply #1 on: 02 October 2006, 22:12:12 »
Got the same problem myself mate , >:( afraid I don't know how to remove the strip , but hopefully someone here does and I may takle the job myself ;)
Re: Rust bubble
« Reply #2 on: 02 October 2006, 23:09:58 »
Thought i had better get it sorted sooner rather than later, by next summer there will be no door left
nixoro
  • Hitchin, Herts
Re: Rust bubble
« Reply #3 on: 03 October 2006, 09:11:44 »
I have this trouble as well unfortunately, the worst rust I had was under the door strip so have started to sort this first.
I believe the window rubbers are screwed in place somehow, I think the screws are visible with the window down when looking in the seal.
HTH :)
Re: Rust bubble
« Reply #4 on: 03 October 2006, 14:07:11 »
HTH :)
Cheers [smiley=thumbsup.gif] I shall have a look this weekend weather permitting
markrl
  • London
Re: Rust bubble
« Reply #5 on: 03 October 2006, 18:08:14 »
There is no screw on the rubber windows seals they simply prise out. They are a fairly tight fit so use some sort of nylon lubrication (Holts electric window lubricant is good for the job) if necessary. You'll need to replace the rubber seal once out as they tend to go out of shape once pulled. Replacements are about £23 each. I have just had the same problem on a rear door (a small rust spot) repaired by my local body shop (in Sidcup) for £80 plus the cost of a new rubber seal. They have done an excellent paint job but the six million dollar question is will the rust come right back? - Time will tell how good the repair really was. What the cause of this problem which seems eventually to afflict almost all Omega's once they get past the 7 year mark I really don’t know for sure but I suspect its probably the result of poor manufacturing during the process when the panel was originally pressed (using stretched steel) as the paint actually seems perfectly fine. This type of problem has also affected the mighty Mercedes E class once again the result of poor manufacturing of a pressed and stretched steel panel. Corrosion in this area was never a problem on the Senator (although there were sadly many others) and seems to be a customer benefit introduced with the new Omega model.
Re: Rust bubble
« Reply #6 on: 03 October 2006, 21:37:07 »
Thanks Mark ;)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Rust bubble
« Reply #7 on: 03 October 2006, 21:42:04 »
Been wonderin about this myself. Think I can derust with the wire brush on my mini drill but I'm wondering what to fill the paint back flat with before I topcoat. Any ideas folks?
TuBy's new whipping boy.
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Rust bubble
« Reply #8 on: 03 October 2006, 21:46:28 »
Is this by window rubber?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Rust bubble
« Reply #9 on: 03 October 2006, 21:49:10 »
Yep Timbuk the classic place. Thinkin I could repaint with an airbrush to minimise the overspray.
Timbuk
  • Telford
Re: Rust bubble
« Reply #10 on: 03 October 2006, 21:57:29 »
Sorry Captain, i think i was reading into this that you were gonna try and do it without removing the seal :o. plain old body filler mate is the simple answer, i know it probably isnt going to be very deep but its the best thing to use. treat the rust if any, fill, wet and dry, fill, wet and dry, primer , paint , laquer. Airbrush is a good idea [smiley=thumbsup.gif]. And once youve done it , post a pic, if its any good i will let you do mine ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Rust bubble
« Reply #11 on: 03 October 2006, 22:01:24 »
I'll put it on the todo list. Gotta do the engine stuff first though, and swap the ns wing.
theolodian
  • I need a new avatar.
Re: Rust bubble
« Reply #12 on: 03 October 2006, 22:02:04 »
Yeah, this is going to be a project of mine soon too.  Anyone feel like doing a guide?
Timbuk
  • Telford
Re: Rust bubble
« Reply #13 on: 03 October 2006, 22:08:59 »
I need to do mine too, have had some dealings with bodyshops in the past and done a few write offs in my time , so if you fancy a little body repair party while im still in cov i am quite happy to give you a hand. Only thing is Theo the weather is getting colder and its not going to help, unless youv'e got a spray booth in your back pocket ;D
Re: Rust bubble
« Reply #14 on: 03 October 2006, 22:12:09 »
Do I detect a 'door repair party' - mine needs doing, and I ain't got a clue with bodywork. Or mechanics. Or electrics....
