Author Topic: central locking  (Read 2663 times)
vauxhall mad
central locking
« on: 10 October 2006, 20:35:00 »
hi i have a 95 2.5 td omega i lock it with the remote and a few seconds later it unlocks itself i have unplugged front solinoids and door lock switches it still does it unplugged nsf door cured it so i replaced the loom on that door put it all back together and itdone it again even if you lock it with key it does it help >:(
Re: central locking
« Reply #1 on: 10 October 2006, 20:48:46 »
Strange locking/unlocking issues are normally result of knackered microswitches in DRIVERS door.
When my main battery was knackered a couple of years back I had a couple of incidents of getting back to car to find it unlocked, and I was sure I locked it (though you do doubt yourself). Not sure if thats relevent or not...
Gwilym
  • Bridgwater, Somerset, UK
Re: central locking
« Reply #2 on: 10 October 2006, 20:48:52 »
I had a car (i think it was a mondeo?) that did that and it was because one of the door catches was sticky so the door wasn't registering as shut and the locking wouldn't work.
Could be the same thing?
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Re: central locking
« Reply #3 on: 10 October 2006, 20:49:42 »
Oh, and welcome to the site  :y
Matchless
  • Nottingham
    • A white van
Re: central locking
« Reply #4 on: 11 October 2006, 11:46:12 »
Check that all the lock buttons are going fully down, if one isnt getting to the fully locked position then the controller will unlock the doors again (as if an occupant had pulled one of the buttons up)
You can manually lock each door in turn then lock the rest on the remote to work out which one is causing the problem.
Could be a sticky mechanism due to old grease / rust or a knackered motor.
