Pages: [1] 2 3 4 5   Go Down
Author Topic: Can't Start Car - Please Help  (Read 19585 times)
sophos9
  • Norfolk
« on: 01 October 2006, 21:29:25 »
Hi all, turned the key in the Omego tonight and it did not fire, kept on trying and nothing.
I checked all the fuses (in the cabin and out).... all good!
Pulled the fuel line off (19mm) turned over - no fuel at all
Undone the multiplug on the fuel pump and check for voltage whilst turning over - nothing!!!
Please, someone tell me this is the fuel pump relay.... :-/
If it is, does someone have a part number for a 1997 3.0v6
Thanks loads for your help in advance....
Re: Can't Start Car - Please Help
« Reply #1 on: 01 October 2006, 21:33:09 »
Done a paperclip test?
sophos9
  • Norfolk
« Reply #2 on: 01 October 2006, 21:35:53 »
Hi mate....
Must admit, did not. No EMS light at all, used the car this morning - all was good!
Does relay trigger a fault code?
Problem is, car is now some 20 miles away....  :-/
« Reply #3 on: 01 October 2006, 21:37:41 »
Don't think relay would trigger a code. But best make sure the ECU is happy, in case of sensor failures, eg crank sensor.
sophos9
  • Norfolk
« Reply #4 on: 01 October 2006, 21:42:19 »
The car has been perfect until a week or so ago where once or twice, the car took about 2 seconds to start instead of the usual fire as soon as engaged
I'm fairly confident there would not be fault codes, I will check it tomorrow but really need to have the most probable fix with me   :-/
How much is a new relay? Is this probable?
« Last Edit: 01 October 2006, 21:42:51 by sophos9 »
« Reply #5 on: 01 October 2006, 21:44:15 »
I don't think fuel pump relays are as problematic on Omegas as they were on earlier cars...
sophos9
  • Norfolk
« Reply #6 on: 01 October 2006, 21:49:57 »
Bah....  :-[
What are the probables...?
Immobiliser
Sensor
ECU
Fuse
Relay
Anything else?
« Reply #7 on: 01 October 2006, 21:53:41 »
Immobiliser would cause EML to flash...
Most sensors will allow car to start, just go in to limp. Crank sensor is an exception. There is a fuse for fuel pump - Fuse 19 IIRC...
theolodian
  • I need a new avatar.
« Reply #8 on: 01 October 2006, 21:55:16 »
Bah....  :-[
Immobiliser
Sensor
ECU
Fuse
Relay
Anything else?
Out of fuel?  :o  Hey, you'd be surprised!   ;D
Kev may have some ideas . . .  ;)
sophos9
  • Norfolk
« Reply #9 on: 01 October 2006, 21:56:26 »
EMS light goes off whilst cranking, if crank sensor was borged then surely EMS light would stay on whilst cranking?
sophos9
  • Norfolk
« Reply #10 on: 01 October 2006, 21:57:11 »
@ theolodian -  ;D
It has petrol in it!  ::)
« Last Edit: 01 October 2006, 21:59:41 by sophos9 »
sophos9
  • Norfolk
« Reply #11 on: 01 October 2006, 22:14:27 »
Are the fuel relays the pink ones under the bonnet? Does one switch the fuel pump whilst the other switches the fuel rails?
Are they the same relay and can I get away with buying 1? How much from Vauxhall and do they usually keep them in stock?
Cheers!!
sophos9
  • Norfolk
« Reply #12 on: 01 October 2006, 22:37:10 »
Ok, found the relays in a picture....
Anyone.. HELP?
« Reply #13 on: 01 October 2006, 22:45:09 »
I think the 2 pink relays are identical.
Make sure you go with your paperclip, and some spare fuses, and a meter...
sophos9
  • Norfolk
« Reply #14 on: 01 October 2006, 22:48:02 »
Hey mate, thanks again for your help.
The relays are the same Part Number: 90494959, the same relays as on the X20XE etc...
Will buy a new relay, already checked all the fuses - all are fine but will take some anyway and will take a paperclip.
I know its a longshot, whats the most likely if not the relay?
Pages: [1] 2 3 4 5   Go Up
