Author Topic: How do I check Automatic Tranmission Fuid?  (Read 4187 times)
Gwilym
  • Bridgwater, Somerset, UK
« on: 11 October 2006, 16:50:52 »
Whilst filling up today I decided to be very thorough and check all my levels of everything!
Petrol - Low (obviously as I went to the garage to fill up)
Coolant - Low (See previous thread on my leak - to be sorted Tuesday)
Oil - Fine
But Then
Auto Tranmission Fluid - after 5 minutes I stopped looking. On my Jeep Cherokee I had a dipstick but I couldn't find one on the MV6. Consulted the handbook and could find no reference to one. Is there one? Is it a viewing window or do I just wait for a warning on the dash!
I know I am showing a great degree of stupidity but HELP ME PLEASE
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Re: How do I check Automatic Tranmission Fuid?
« Reply #1 on: 11 October 2006, 16:53:38 »
Its a bit more involved but, not to hard to do.
Checking the auto box fluid level
Gwilym
« Reply #2 on: 11 October 2006, 16:55:52 »
Um. I take it as there is no easy way of checking that it is not a regular thing that needs doing? I don't have a problem with tranmission. I was just being efficient (and incompetent) and thought I would check.
How often do you check / or change yours?
« Reply #3 on: 11 October 2006, 16:57:14 »
Fluid change every 50K miles and check the level every 20K miles
Gwilym
« Reply #4 on: 11 October 2006, 16:58:32 »
Cheers. I will do it soon then
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« Reply #5 on: 11 October 2006, 16:59:07 »
Funnily enough, I did mine today! I didn'tt fancy lying under a car as heavy as the Omega with it on axle stands and the engine running, so I asked my friendly Mot tester if I could check it on the 4 post ramp. didn't need much fluid at all and was a damn site easier ands safer.  :)
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
theolodian
  • I need a new avatar.
« Reply #6 on: 11 October 2006, 17:03:21 »
I doubt mine has ever been changed.  I really need to find a place that will do it, a couple have said no so far.  Should I have them change or clean the filter?  (149K)  I was going to do the diff too.  What is the suggested interval on that?
« Last Edit: 11 October 2006, 17:04:07 by theolodian »
« Reply #7 on: 11 October 2006, 17:56:55 »
As an Omega uses the same gear box as it predecessor which had a dip stick tube on the auto box I wonder if it's possible to fit a dip stick to an Omega! Even my wife's Astra has a dip stick on the auto box!
mijfife
« Reply #8 on: 11 October 2006, 18:31:48 »
I must admit, I found it strange that it didn't have a dip stick. Every other auto I've owned has had one!
Cheers Jim
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #9 on: 11 October 2006, 18:33:11 »
The wife's clit hasn't.
I like red cars
Taxi_Driver
« Reply #10 on: 11 October 2006, 19:31:07 »
I was quoted about £100 for vx dealer to change the ATF and filter.....that was Masterfit price tho..
HTH
« Reply #11 on: 11 October 2006, 20:42:50 »
Well your in for a shock....its not the same....its a later revision of, even the sump pan is a different shape with a different gasket etc.
The bottom line is that the gearbox 'shouldn't' loose fluid unless there is a leak.........which you would like to think would obvious.
Gwilym
« Reply #12 on: 11 October 2006, 20:56:18 »
Cheers Jim
Not just me then
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #13 on: 11 October 2006, 23:10:02 »
Something i need to do as instinct - and nothing more apart from paranoi tells me something is starting to go amiss with my auto box, rolling back on hills whilst in drive ......fluid level check first.... :(
Page created in 0.246 seconds with 20 queries.
