Author Topic: AR25 Gearbox  (Read 3053 times)
JONNYWAKEY
  • Bilsthorpe Nottinghamshire
AR25 Gearbox
« on: 15 October 2006, 11:33:25 »
Guys, I need some advice.
I have a 2001 2.2CDi omega with 4 speed auto box (AR25), I have spent a fortune on the car and its still not right.
Ive had gearbox flushed and refilled, had new MAF sensor and camshaft sensor, last year I had new Oil pressure sensor in gearbox.
Still going into limp home mode when hot starting, code reader calls up P0700 and P1700 but only SVS light on, not EML.
Is the TCU at fault or is it something internal with the box? when cold started car drives superb?
Please help, Im in notts area if any Meega experts about!
Cheers
John
Taxi_Driver
Re: AR25 Gearbox
« Reply #1 on: 15 October 2006, 12:17:43 »
Welcome to the 2.2 Club  :(
Have a look at these threads
http://www.omegaowners.com/forum/YaBB.pl?num=1160654257/0
http://www.omegaowners.com/forum/YaBB.pl?num=1160621228
Sound much the same??
Seems to be getting a common problem on 2.2's  :(
I hoping TheBoy is gonna have time to do a live data check with his Tech2, on mine to see whats going wrong when mine does it  :)
JONNYWAKEY
Re: AR25 Gearbox
« Reply #2 on: 15 October 2006, 13:37:01 »
Thanks for links, sounds exactly the same, been looking through TIS2000 vauxhall programme, doesn't really give any indication of problem, I'm thinking like you, it must be the Gearbox fluid temp sensor or some sort of heat sensor / heat related problem, car fine when cold starting.
May take to Vauxhall and ask them to do a live analysis on Tech 2!
Not taking and trash of them though, been fobbed off by them b4.
I will keep the forum updated on any new info
Many thanks
Jonny
Re: AR25 Gearbox
« Reply #3 on: 15 October 2006, 18:59:22 »
TD, I had a word with Marks_DTM, and if we can get a live capture of whats happening, I can email to him to see if he can figure out.
Might be worth fluid change though anyway...
Taxi_Driver
Re: AR25 Gearbox
« Reply #4 on: 15 October 2006, 19:31:54 »
I doubt if they would know how to use a TECH2 to do that!
Probably only know how to read codes and do the odd programming
You may be lucky in finding a dealer that knows how to do it  :-/
