Author Topic: Auto Gear  Selection at night.  (Read 2269 times)
Big_Al
« on: 15 October 2006, 21:44:06 »
Heres one Guys. any advice greatly appriciated. Auto selection in daylight & without lights on I'm getting a nice bright yellow indicator to show which one is selected. But  as soon as you switch on lights this goes out & nothing can be seen. I'm not sure what should be happening. Should the  P R N D 123 light up whilst the lights are on? If so any possible remedies from you Guys with the know how.  Thanks, Big Al
Taxi_Driver
Re: Auto Gear  Selection at night.
« Reply #1 on: 15 October 2006, 21:49:26 »
Yep it should still light up to which gear you have selected......thats an unusual one and i carnt think of an explanation for it.....apart for maybe a bad earth....sorry m8  :(
Hopefully someone thats come across that one before will be along shortly  :)
« Reply #2 on: 15 October 2006, 21:52:06 »
I don't think they do all light up when lights on, only the function selected, same as with lights off...
Big_Al
« Reply #3 on: 15 October 2006, 22:00:22 »
Thanks for replying. The selected yellow dot indicator goes out when you turn lights ON. Should this stay on, but dimmer than when lights are off? Or should the P R N D etc. itself light up to which ever one is selected?  Have not had an auto before so I'm not sure.  Big Al
« Reply #4 on: 15 October 2006, 22:16:21 »
I'll have to check next time I'm in it....  :-[
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #5 on: 16 October 2006, 06:46:58 »
The P,N,D,1 ...etc should stay lit up with either lights on or off, and obviously the wee dot should only light up which gear you have selected. These are also controlled to the dash brightness control under the light switch, so check that you haven't got that turned down too far.
After that it must be a contact somewhere, but god knows where you start.
First question would be, have you been fiddling anywhere recently, and might have disturbed anything?
We had a long conversation about this very thing at the jockular meet yesterday, as 2 of the guys are suffering the same thing as you.
Good luck.
RonaldMcBurger
« Reply #6 on: 16 October 2006, 07:58:40 »
Bulb should dim as said above. Either it is a tow element bulb, or has a wiring fault.
« Last Edit: 16 October 2006, 07:58:54 by RonaldMcBurger »
