Author Topic: Changed my plugs  (Read 2827 times)
Changed my plugs
« on: 16 October 2006, 21:57:18 »
I changed my spark plugs today and the first thing I noticed was 3 of the plugs were only hand tight. Now I know you shouldn't tighten them to much but i'm pretty sure you shouldn't be able to undo them by hand :o. I also noticed a couple of plugs had a tiny amount of oil on them as in a bit around the hexagonal part of the plug but it wasn't wet it looked burnt. Does anyone think I need to change the rocker gaskets or do you think I will get away with cleaning the breathers.
Ta in advance
Pete
Re: Changed my plugs
« Reply #1 on: 16 October 2006, 22:00:21 »
try cleaning breathers and check again in 1000 miles...
« Reply #2 on: 16 October 2006, 22:23:05 »
If the cam covers were leaking then you wouldn't be able to see the plugs!
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #3 on: 17 October 2006, 08:29:19 »
I can vouch for that, when they went on my old miggy the number 4 plug was totally submerged - when you removed the HT lead, you couldn't see any part of the plug :o
« Last Edit: 17 October 2006, 08:29:59 by sounds2k »
« Reply #4 on: 17 October 2006, 08:43:12 »
I just changed 2 rocker gaskets on a V6 omega yesterday - I can confirm that, the plug wells were actually full right to the top with oil - none of the plugs were visible at all. I'm amazed it ran...
« Reply #5 on: 17 October 2006, 09:32:07 »
Thanks fellas, its just me being paraniod then :y
The Barge Captain
« Reply #6 on: 17 October 2006, 13:09:46 »
Yup - seen that too.  Had to use a large syringe and a length of tube to suck the oil away befor i could even find the plug.  Amazed that it ran at all.
