Author Topic: Alarm and trim problem  (Read 2358 times)
Trevcar
« on: 16 October 2006, 13:40:15 »
Dear All
I have two problems with my otherwise super Omega, one is the alarm keeps going off, how do I disconnect the hooter sound as no-one takes any notice anyway. The other is the rear door trim keeps lifting and catching the drivers door, tried to stick it with araldite and no-nails, but didn't work any ideas welcome please.
nixoro
  • Hitchin, Herts
Re: Alarm and trim problem
« Reply #1 on: 16 October 2006, 13:53:30 »
With regards the Alarm check the bonnet plunger is not loose this can cause the alarm to go off.
Worked for me cable tied it and not had any problems with it since.
HTH :)
« Reply #2 on: 16 October 2006, 14:17:59 »
wrt trim, a member here used an epoxy with some success.
wrt to alarm, is it horn (check bonnet switch as suggested) or power sounder?
« Reply #3 on: 16 October 2006, 17:25:35 »
To proove its the bonnet switch you can simply unplug it, if it no longer goes off then you know what to fix.
wigan pier
  • Keep on Trucking
« Reply #4 on: 17 October 2006, 00:16:29 »
Dear All
For the rear door trim remove it.. get one from your local scrappy..just take your time peeling it off with luck (done it twice) it should come off almost perfect..then use some glue (I used evostick) with the clips and all should be fine..just a little care needed. :y
Gord.
Omega 2.5 cdx and Vectra 2.5 cdx estate
Gwilym
  • Bridgwater, Somerset, UK
« Reply #5 on: 17 October 2006, 19:08:57 »
I had the same problem with the trim on '94 CDX. You will not get it to stick back for any length of time. I managed to get it to stay for 3 weeks at most then it would peel again.
 I agree either breakers yard or new one is IRO £50,
« Last Edit: 17 October 2006, 19:09:30 by Gwilym »
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
