Author Topic: Engine Flush  (Read 2907 times)
Essex_Andy
  • Have a guess?
Engine Flush
« on: 18 October 2006, 11:49:02 »
Whats the thoughts/recommendations on using engine flush prior to oil changes?
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Re: Engine Flush
« Reply #1 on: 18 October 2006, 11:53:58 »
Not required, just change oil more regular if the stuff in there looks bad...
Essex_Andy
  • Have a guess?
Re: Engine Flush
« Reply #2 on: 18 October 2006, 11:58:51 »
thanks.
I suppose if looks crappy....hot oil changes every 2000 miles? ? ?
On my motorbike I change the oil at half the recommended milage intervals and change oil filter every other oil change.
Anyone do the same on cars?
Bo Bo
  • Coventry
Re: Engine Flush
« Reply #3 on: 18 October 2006, 12:07:23 »
Never go over 5k with mine, usually a lot less, but then I don't do 5k a year  ;)
Re: Engine Flush
« Reply #4 on: 18 October 2006, 12:16:16 »
My MV6 has oil/filter change every 3 - 4k. Helps keep engine tip top, and costs around a tenner to do using Vx Semi and Vx own filter.
Admin
Re: Engine Flush
« Reply #5 on: 18 October 2006, 12:56:54 »
Only use engine flush if things are really bad.
Be careful though, it is not so much what it get out, it is what is dislodged and moved elsewhere in the engine!
As Jaime says, short oil changes with Vx Semi synth and Vx filter.
On a car you don't know the history on, I would change every 1,000 miles for 3 changes.
The Administrator.
