Author Topic: Breather pipe on axle or gearbox?  (Read 2945 times)
nero161
  • gateshead tyne and wear
  • I get dirty on a w/e!!!!!!!
« on: 20 October 2006, 22:34:56 »
Can anyone help....
I have a small pipe coming up from on top of the gearbox somewhere it ends near the break servo and is not connected to anything.
Should it be connected and if so where.
Could this cause my car to have no power upto 2500rpm?
as lately it has been suffering from this problem.
thanks for any help
p.s. 2000 2.2cdx
Re: Breather pipe on axle or gearbox?
« Reply #1 on: 20 October 2006, 22:36:31 »
Thats the autobox breather and isn't connected....
STMO123
« Reply #2 on: 20 October 2006, 22:42:50 »
Can anyone help....
thanks for any help
p.s. 2000 2.2cdx
That sounds suspiciously like multi rams
nero161
« Reply #3 on: 20 October 2006, 22:45:59 »
Glad the pipes not connected...
Mulit rams?  are they easy to fix?  Where are they?
« Reply #4 on: 20 October 2006, 22:47:34 »
Unlikely on a 2.2, as it ain't got any... ;)
« Reply #5 on: 20 October 2006, 22:49:17 »
How well does it idle?
STMO123
« Reply #6 on: 20 October 2006, 22:50:55 »
Doh! Doh! Doh!
« Reply #7 on: 20 October 2006, 22:52:21 »
Doh! Doh! Doh!
yeah, 4 pots are missing some bits - multirams, a couple of cylinders, 70 odd horsepower....  ;D
nero161
« Reply #8 on: 20 October 2006, 22:53:53 »
seems of sometime then goes up and down and seems to run rough. above 2500rpm seems ok.
when you rev it in park it seems to stutter untill it sets to 2500rpm.
« Reply #9 on: 20 October 2006, 22:55:51 »
check all the intake hoses for leaks...
nero161
« Reply #10 on: 20 October 2006, 22:59:01 »
Will do that tomorrow while i am changing the oil in the gearbox and engine.
thanks for your help :y
STMO123
« Reply #11 on: 20 October 2006, 23:05:32 »
Doh! Doh! Doh!
No need to rub it in :-[
nero161
« Reply #12 on: 21 October 2006, 18:52:02 »
changed the plugs today and when we took the coil pack thingy off there was a one of the springs that go onto the plugs had come off. put it back on and runs like a dream.
« Reply #13 on: 21 October 2006, 19:04:02 »
Fantastic news :), and tahnks for the update on the cure :y
