Author Topic: Finally got fault code from Tech2 - PO100  (Read 6604 times)
Taxi_Driver
Re: Finally got fault code from Tech2 - PO100
« Reply #15 on: 24 October 2006, 07:41:30 »
Thanks Taxi Driver - I am the spanner driving the car, cos the dash light illiminated orange is the 'Control Indicator for exhaust' according to the manual.
Air filter changed at last service 2m ago - still an airleak?
Ok so its the emissions light......afaik that comes on if running to rich or to lean and determined by the lambda sensors
Re-reading your original post i now read it as it runs ok now when cold and changing the temp sensor fixed the rough idle when cold.
If so it might be worth getting the exhaust emissions checked to see if it is runnng lean/rich..and then go from there.......if they are fine and theres no performance issues then it could be just iffy sensors
HTH
Page created in 0.01 seconds with 18 queries.
