Author Topic: Re: what 2 look 4 when buyin a elite?  (Read 3137 times)
Markjay
  • London
« on: 26 October 2006, 21:26:22 »
Then clean the breather - clogged ones result in leaky cam cover gaskets.
Alas, no more Omegas....
Markjay
  • London
« Reply #1 on: 26 October 2006, 21:27:52 »
What year is the Elite? What mileage?
Also, change engine oil and all the filters (oil, air, fuel) - unless you know when it was last done.
And if the auto gearbox is not as smooth as it should be, get the ATF replaced.
chris b
« Reply #2 on: 26 October 2006, 21:30:23 »
hi m8.av got a bill 4 the cam bellt  and it has a sticker when and milage it was dun under the bonit. but how do i no the rollers were dun with out takin the cover off?
chris b
« Reply #3 on: 26 October 2006, 21:35:21 »
hi. its a 1998 with a high 142.000 on the clock. but the good thing is i am only the 2`nd owner. it has a full s,h an runs very smoth. even the gear change is smoth. :) :)
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #4 on: 26 October 2006, 21:44:50 »
Should be on the bill, how much were the parts?
chris b
« Reply #5 on: 26 October 2006, 22:03:18 »
the bill just states cam belt and the cost was £207. :-/
Timbuk
  • Telford
« Reply #6 on: 26 October 2006, 22:06:10 »
Trouble is , its the tensioners that fail, if it is only the belt that has been changed i wouldn't risk it :-/ can you contact the garage that did it?
Markjay
  • London
« Reply #7 on: 26 October 2006, 22:12:47 »
142k ain't high for a 'meega...  ;)
chris b
« Reply #8 on: 26 October 2006, 22:19:25 »
all have a go 2 moz. thanks 4 ya help. :y
Markjay
  • London
« Reply #9 on: 26 October 2006, 22:19:39 »
Agreed, if you can't confirm with the garage that the tensioner has been changed then change both the tnesioner and the belt anyway - and do the water pump as well while you'r at it. How long/mileage ago was the cambelt change anyway?
Also, the spark plugs are good for 40k/4y, but if you are not sure when they were last replaced then get them done - they are only around £3 each from a Vx dealer.
chris b
« Reply #10 on: 26 October 2006, 22:22:56 »
got 2 admit it doesn`t drive and go`s like 142k m8. they don`t hang about do they? :y
chris b
« Reply #11 on: 26 October 2006, 22:36:12 »
it was 10.000 ago acordin 2 the book. and a full service 4000 ago. :y
Markjay
  • London
« Reply #12 on: 26 October 2006, 22:42:22 »
have a look at:
http://www.omegaowners.com/forum/YaBB.pl?num=1152655082
