Author Topic: Coolant flush I done it!!!!  (Read 1454 times)
VX1
  • Reading, Berkshire
« on: 08 September 2007, 17:26:33 »
Well done the coolant flush today after seeing the water looked like brown rusty water. Bought some rad flush put that in when at work before I came. Drove home with the flush in the cooling system got home and emptied the water. Brown water came out, Hose pipe in the expansion tank and left the rad plug out and flushed the water through. Then I put the plug back in and filled with water about five times until the water came out clear. Whilst I was doing that decided to take the top and bottom hoses off and flush the rad out as well due to seeing rusty water coming out when the last drops of water coming out of the plug hole.
Connected everything back and filled with water to approx half way then topped up with antifreeze. Started the car let it run then filled up with antifreeze again until the level stablised in the tank. Left the car running for about half an hour checked and left to cool down and retopped up with water. Now thats all done I can be rest assured that the coolant will keep the cooling system nice and clean until it needs doing again next year. Next job to be done is the engine flush and a bloody good service. Air, oil, pollen filter, fuel filter plugs and leads then she might just run better and the fuel consumption should improve a bit.
Vx Trade club card holder
Halfords trade card holder
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Coolant flush I done it!!!!
« Reply #1 on: 08 September 2007, 17:54:47 »
Sounds like a good day. Must be easier to do all that with the sun on your back.  8-)
[size=24]        [/size][/b]
VX1
« Reply #2 on: 08 September 2007, 17:56:36 »
Well, wasn't to bad needed to be done though!
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #3 on: 08 September 2007, 17:57:27 »
Sounds like a good job done then there, well done :y :y
By the way................Where did you flush the old water too??? :o :o
VX1
« Reply #4 on: 08 September 2007, 18:23:08 »
Oooopppssss  ::) On the ground then it went down a drain with plenty of water to dilute it  :-[ :-[ :-[
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #5 on: 08 September 2007, 18:24:25 »
Oh you naughty man  >:(
Now go and sit in the corner, take your belt off and get your wife to spank you;D ;D ;D
« Last Edit: 08 September 2007, 18:24:59 by Crazydad »
Golfbuddy
  • Cornwall
« Reply #6 on: 08 September 2007, 18:27:44 »
No, it's alright. You're allowed to do that in the Thames Valley. In fact it actually improves the local water quality.  :)
VX1
« Reply #7 on: 08 September 2007, 18:44:00 »
[/highlight]
Drat I was hoping to get her to do that and have a good kinky night tonight  ;)
