Author Topic: Steaming up  (Read 6900 times)
BILL0BLU
  • Isle of Anglesey
Re: Steaming up
« Reply #15 on: 03 November 2006, 00:25:42 »
After reading the info about windows misting up and having the same problem I checked mine this afternoon and found that although there was no crud to mention there was about 4inch of water. I managed to get an air line down to the drain hole and blew it out. Water all gone now so hopefuly no fogged up windows. A point to watch out for if you try to dig out the drain hole with some thing like a long screw driver is to be careful not to damage the wireing loom that runs down close to the drain hole :y
Boiler Man
  • Sale, Manchester
Re: Steaming up
« Reply #16 on: 03 November 2006, 01:23:35 »
Think you might find that the pollen filter doesnt only stop pollen but cr*p being pulled through your heater battery or matrix or heat exchanger or whatever you call it.
so you might have to give that a blast in the spring to clean it up, along with the resident spider.
having said all that, mine has been off for months. happy spiders. for the winter at least. [smiley=evil.gif]
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
