Author Topic: Versions of Omega with Cruise as standard ?  (Read 6349 times)
tommoynihan
« on: 04 November 2006, 17:22:51 »
Can anyone tell me which models of Omega (2001 onwards) have cruise control as standard (if any) ?
Failing that, was it part of a specific option pack ?
Can it be retrofitted and at what cost, either by DIY or specialist ?
Finally,  on the standard factory fitted version, how is it actuated i.e. button (on steering wheel ?) or stalk on steering column (dedicated to cruise or shared with other functions) ? Does a light come on on the dashboard when cruise is on ? I'm asking this last question because I've rung several garages to ask if their particular car has cruise, and then they (live on the phone) get into the car, start it up, and start playing with all the switches and stalks to see if any of them flash up a 'cruise' light. Needless to say, I haven't found one yet ...
Thanks in advance.
Kes
Re: Versions of Omega with Cruise as standard ?
« Reply #1 on: 04 November 2006, 17:41:51 »
Hi dunno which versions. The control is two buttons on the end of the left hand stalk , no light on that I have seen .
« Reply #2 on: 04 November 2006, 18:13:43 »
You should have a read of this, it shows you exactly how to install cruise on a Facelift Omega
http://www.omegaowners.com/forum/YaBB.pl?num=1152953478
On Facelift models, Cruise Control was an optional extra on GLS & CD spec.
Not sure about MV6 on the facelift, think its optional extra.
CDX & Elite Models had cruise as standard.
Do you have a manual or Auto? - If a manual you may need a clutch switch.
All you need a Indicator stalk which has the extra cruise buttons, and get it enabled by a local Vx dealer, or you may have someone near you with Tech2.
Tech2 is the communication software used with Vauxhalls.
Get it enabled on the car, and thats it job done it should work.
I installed cruise on mine a few months ago, for £20  :) - It was a £400 factory fit option!
tommoynihan
« Reply #3 on: 04 November 2006, 18:23:13 »
I'm looking for an automatic.
Just to confirm if I understand you correctly.
I can add cruise control to say a post 2001 2.2 CD auto, by replacing the indicatior stalk with one that has cruise buttons (from either a scrappy or new from a vauxhall dealer), and then all I have to do is go that a Vauxhall dealer and get it enabled ?
Without sounding too naive, will they do this, and how much will it cost ?
Thanks.
« Reply #4 on: 04 November 2006, 18:34:55 »
Thanks.
Yes that is correct.
The facelift Omega came out in 1999. You can always tell a facelift because it has the electric window buttons on the doors.
A Vauxhall dealer will do this, some are better than others. Some will stay you need this and that, tell us what area you based in and someone should be able to recommend a dealer.
Dealers charge around £40 + vat generally just to plug tech 2 in... so your looking around that figure.
Where exactly are you based? - One of the admins here called "TheBoy" has discounted prices for members here:
http://www.omegaowners.com/forum/YaBB.pl?virboard=GenChat;num=1161364514
« Last Edit: 04 November 2006, 18:56:55 by tunnie »
Taxi_Driver
« Reply #5 on: 04 November 2006, 18:51:45 »
I'd go for a CDX or higher spec......as not only do you get cruise as standard but you also get HID headlamps.....a much better upgrade than the standard filament bulbs  :y
Taxi_Driver
« Reply #6 on: 04 November 2006, 18:54:26 »
- One of the members here called "TheBoy" has discounted prices for members here:
Ohhh you called Jaime a member and not an administrator  :o
You'll be getting posts docked for that Tunnie  ;D
« Reply #7 on: 04 November 2006, 18:57:43 »
no i did'nt  ;)
Taxi_Driver
« Reply #8 on: 04 November 2006, 19:12:19 »
no i did'nt  ;)
Yes you did, thats why i quoted you....the quote carnt be changed by us humble members  ;D
« Reply #9 on: 04 November 2006, 19:25:18 »
no i did'nt  ;)
Bugger!  >:(
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #10 on: 04 November 2006, 19:36:25 »
 ;D ;D foiled again Tunnie.
TuBy's new whipping boy.
Taxi_Driver
« Reply #11 on: 04 November 2006, 19:48:27 »
no i did'nt  ;)
Bugger!  >:(
Tho as i posted it i can.....whats it worth Tunnie  ;D
« Reply #12 on: 04 November 2006, 20:15:47 »
no i did'nt  ;)
Bugger!  >:(
hehe!
Kinda miss being on here 24/7 only get the chance in evenings to come on really. But should be back with a vengeance for about a month next summer! .. but then will disappear for 2 months!
Taxi_Driver
« Reply #13 on: 04 November 2006, 20:23:24 »
no i did'nt  ;)
Bugger!  >:(
hehe!
Oh well....as no promise of folding stuff in the post i'll leave it as it is then  ;D
tommoynihan
« Reply #14 on: 04 November 2006, 21:50:38 »
Unfortunately, I'm based in the North West - Liverpool/Manchester area
I've haven't got a Vauxhall at the moment, but in a previous lifetime with a Cavalier SRi and then a Carlton 2.2 CDi auto, I learned not to be very impressed with my local Vauxhall dealers.
Can anyone recommend any good ones up North ?
